Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 12-13-2014, 06:15 PM   #21
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Bob, it was less costly for me to read the forums when you were laying low. Now I have to get one of these since the stuff you use always makes so much sense to me. Hope you are shovelled out. Jim
Jim Flower is offline   Reply With Quote
Old 12-13-2014, 06:57 PM   #22
Storm Master
Ampman's Avatar
2005 25' Classic
We use the EMS-HW30C 30 Amp Hardwired unit which has a slight hum when operating so placement is a consideration. Also use the TRC Digital Monitor just to keep an eye on the power from time to time due to work addiction. Plus it gives another readout on a downstream circuit. The absolute best protection available is to not having your sensitive equipment plugged in at all. Other than that there are many devices out there to suit your needs based on what you want to protect. When at home and a storm is near we unplug all electronics we don't want to lose except a sacrificial cheap TV to watch the weather. Then I leave to go battle the storm. When we leave on trips we unplug the same stuff. Don't forget about any hardwired cable tv and phone lines either, unplug em too. A lot of calls post storm have to deal with blown out cable tv and phone boxes. On the road I check every pedestal before hooking up. Not paranoid about the power but treat it like any other routine task for RVing.
Ampman is offline   Reply With Quote
Old 12-13-2014, 07:43 PM   #23
daveswenson's Avatar
2012 28' International
Olympia , Washington
My thinking. A power monitoring/surge protection unit isn't cheap. Mine was $220. But it's cheaper than an AC unit, cheaper than a fridge. It's insurance. Expensive if you don't need it. Cheap if you do.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 12-13-2014, 10:14 PM   #24
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
By one before you plug into any power source ASAP.
Recently, I had a power surge and/or lightening strike the destroyed the following: Ground Fault Circuit Breaker, Microwave, Converter (on a different breaker that also would not reset until the converter was replaced), Water Pump, MircoPulse Monitor including two sensors, and Solar System repair. The total including labor was around $2,000. When I think of the two heat pumps, furnace, all lighting, 2 TVs and strero, antena booster, hot water heater, refrigerator, tounge and stabilizer jacks, propane sensors, and batteries x 4. I feel real fortunate more damage was not done. Lightening can do strange things like damage disconnected equipment and jump all over the place. When I was flying for a living, I can remember lightening hitting one fiberglas wing tip and going out the other with almost invisable holes left behind in both fiberglass wing tips. Many times we would get hit and no visible damage could be found. However, one time a hit caused a fuel vent fire during descent. The damage was not discovered until after landing. The fire had starved itself of oxygen later on during the descent. So much for Faraday cages Airstreamers. Is it better to place plastic under the tounge and stabilizer jacks or let them rest on the ground? Is the AC ground connected to frame as the DC? If so the trailer would be grounded through the power pedastal. Bad grounds can also cause power surges. Thoughs?
Charles J. "Gus" Gustafson
"Space A"
WBCCI # 4428
Old 12-13-2014, 10:47 PM   #25
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
So is the concensus that a portable unit at the pedistal is best? That way the airstream 30 amp plug is protected? I do like that a hardwired unit is not out in the open for theft.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 12-14-2014, 04:28 AM   #26
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I use the pedestal unit for convenience. They make a device that will allow it to be locked to the cable.
I could see hardwired in some cases, if I had ready access to the power cable and there was plenty of room. Regardless, if it gives up it's life to save your trailer you will have to replace it. A portable unit is a lot easier to replace IMHO.
Aaron
WBCCI #XXXX AIR #2495
Old 12-14-2014, 05:09 AM   #27
"Cloudsplitter"
Thumbs up
Jim,
I'm sorry....the DW always said I was an expensive date.
Weather.....It's pretty normal for WNY.
Nov 20 2014....lot's and lot's
Nov 27 2014...not so much.
ID:	228551   Click image for larger version
Old 12-14-2014, 05:23 AM   #28
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
What ever electrical protection you purchase it should cover not only power surges but also recognize wiring faults in the source and be able to shut off power if voltage is too low. Sometimes it is advantageous to be able to show an RV Park person the fault right on a monitor and get a different space with a good electrical source.
Ms. Tommie Lauer
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 12-14-2014, 05:25 AM   #29
Tincampers's Avatar
Sneedville , Tennessee
I went ahead and got this one:
Progressive Industries PT30C 30 Amp Portable Electrical Management System
Peace of mind is priceless.
Tincampers is offline   Reply With Quote
Old 12-14-2014, 05:38 AM   #30
Msmoto's Avatar
2007 25' Safari
Images: 135
I use their EMS-50PTC and like all the data. Yes, peace of mind.....
Ms. Tommie Lauer
AIR #31871 KQ3H
Old 12-14-2014, 06:11 AM   #31
Jim Flower's Avatar
1997 25' Safari
Thanks for the info mrprez, Msmoto, and Bob. Piece of mind is good. Sold. Jim
Old 12-14-2014, 06:51 AM   #32
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
I should also add that in addition to the power cord surge protector, we leave the (supplied with recent model AS) small power monitor (with three visual indicators) plugged into the bathroom electrical receptacle as a night light ... it just provides another eye to what is going on with the electrical system.
Old 12-14-2014, 10:28 AM   #33
Storm Master
Ampman's Avatar
2005 25' Classic
Every rig has a different location for the main panel and hooking up a hard wired unit may be easy or a pain. The portable unit makes more sense and that's what I will go to when my hard wire unit fries. Plus you can drag it with you if you trade your rig.
Old 12-14-2014, 11:51 AM   #34
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by Silvery Moon View Post
So we use the aforementioned surge guard, and when we're actually drawing on a 30 amp feed, we also use this voltage regulator: http://www.amazon.com/Technology-Res...dp/B00A0RANJ6/
They also make a 50-amp version. It's quite a brick, but we like the extra protection - it could save our heat pump from low-voltage damage. This item boosts voltage by as much as 10% (e.g. from 95 volts) before it gives up, turns off the power to your rig and waits for better conditions before resuming the power feed.
The Progressive solution may be more cost-effective since it protects both against surges and low voltage, but we didn't know about it then.
Thanks for your input. I am looking at getting the Technology Research unit for New Lucy. I have never had a surge protector before. I am reading that this unit is both a surge protector and a voltage regulator. Is this correct?
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 12-14-2014, 12:30 PM   #35
Jim Flower's Avatar
1997 25' Safari
PT 30C has a decent price today at Camping World on line. $218 plus shipping $9. Ordered. Two weeks shipping which is ok for me but a tad slow by today's standards. Jim
Old 12-14-2014, 12:35 PM   #36
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
Buy one.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 12-14-2014, 12:36 PM   #37
Tincampers's Avatar
$215 on Amazon with free Prime shipping or free Standard shipping (you'd have it next week..
Old 12-14-2014, 01:37 PM   #38
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Brian
It doesn't regulate, only monitors the voltage, shutting it off if it is too low or high. Nifty unit, goes through a variety of power checks when first plugged in before it allows power to pass to your Airstream. I feel very good about the power source with this plugged in to protect our electrical system.
Doug and Cheryl
Old 12-14-2014, 02:01 PM   #39
Jim Flower's Avatar
1997 25' Safari
Originally Posted by silverbp View Post
Buy one.
Yup. Got one. And mrprez, I never go shopping after I have been shopping. Another way to avoid being disappointed. But thank you for the heads up anyway. Jim
Old 12-14-2014, 02:10 PM   #40
Tincampers's Avatar
Well, if not for you then for those who follow.
Surge Guard protectors with locking hasp jtbarbee Electrical - Systems, Generators, Batteries & Solar 5 05-03-2014 03:29 PM
SurgeGuard Surge Protectors Kevin Madiso General Repair Forum 4 03-18-2014 07:07 AM
Updates on surge protectors? Scott J-24 Batteries, Univolts, Converters & Inverters 56 08-01-2013 10:29 AM
Surge Protectors and Such.... luckydc Electrical - Systems, Generators, Batteries & Solar 26 08-17-2010 12:08 AM
RV Surge Protectors Tin Hut Electrical - Systems, Generators, Batteries & Solar 4 06-09-2004 05:37 PM
