Old 08-14-2014, 08:44 AM   #1
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Surge protector recommendation?
Before buying a surge protector, I'd like to hear members recommendations on the portable ones. I see various brands priced from the $60 to $250 range.
The RV park where we spend our winters is getting long in the tooth and electrical problems are increasing. A couple of neighbors have experienced damage which I want to avoid.
Is a basic surge protector sufficient or do I need a deluxe one?
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 08-14-2014, 08:59 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
What was the damage and what makes you think a protector may have stopped it?
What do you have in the trailer that is suspectable to fluctuations in city power? The AC is suspectable to low voltage but a protector will do nothing against that.
2004 Excursion 4x4
Old 08-14-2014, 09:18 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use this one to provide a variety of power problems. Low voltage results in high current flow which can damage equipment, electronics. It's on sale now.
Portable Surge Guards With LCD Display - 30 Amp - TRC 34730-001-LCD - Surge Protectors - Camping World
Doug and Cheryl
Old 08-14-2014, 05:22 PM   #4
1964 17' Bambi II
Laramie , Wyoming
Images: 11
More comments? Damages I've seen include fried electronic equipment and fried wiring at the power cord connector on the RV. RV park compensated one resident with free rent.
Antique Pedaler
Old 08-14-2014, 06:06 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
While Howie is right that a surge protector doesn't address low voltage situations, there are combination units that do surge protection, low/high voltage shutoff, AC compressor slow start, polarity check, etc.
I use this one: http://www.progressiveindustries.net/ems_pt30c.htm
Last year, we were at a campground in a very hot/humid weekend and everyone was taxing the power grid. Several times this unit detected low voltage that would have harmed my AC and shut it down until the voltage rose back to a sufficient level.
Recently I had a problem with the shape of the campground pedestal bumping out such that the contact wasn't solid at the pigtail. That heated up one of the blades and oxidized it. I talked with Progressive Industries about it - it's not damaged. I've filed off the oxidation and will be sure to connect tightly even if that means Velcro straps around the pedestal.
Check the link and see what you think. Good luck!
Old 08-14-2014, 08:51 PM   #6
2016 30' Classic
Erie , Colorado
Or the ones from Surge Guard. Campingworld has some great prices on them from time to time. I bought a permanent install 30A model with remote and had it installed when I did the solar install.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
surge protector pip8688 Batteries, Univolts, Converters & Inverters 15 08-09-2010 05:14 AM
