Old 07-22-2016, 02:29 AM   #1
TinVenture's Avatar
2016 19' International
Orange County , California
Surge Protector Installation
My very first post!
I recently purchased a 19' International and after extensive research picked up the Progressive Industries EMS-HW30C.
I just finished upgrading my Converter/Charger but not sure where to install the surge protector. There really isn't much room behind the Converter/Charger and I'm not 100% sure which wires to splice into.
Does anyone have any videos/photos of an install? I've checked and the only videos are on RV's which have easy access to the wires.
I could also access wires under the front dinette/cushion but my understanding is the surge protector should be placed in-line prior to the Converter/Charger.
Any assistance in the actual install for my floorplan would be appreciated.
TinVenture is offline   Reply With Quote
Old 07-22-2016, 04:35 AM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Sorry....I can't help with the install, we use the portable version, easy return if/when it does it's job and has to be replaced under warranty.
Sweet Stream's
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-23-2016, 01:34 AM   #3
TinVenture's Avatar
I really wanted the hard-wired version since it has a higher joule rating and features a digital display readout. It's actually field serviceable so replacement parts can be quickly swapped out without removing the entire unit.
After a call to Vinnie over at Vinnie's Northbay Airstream Repair, he advised me of how little room there is behind my charger/converter. A lot of heat builds up behind there as well. The 25' and larger AS have much more room to install a hard-wired unit.
Looks like I'll be picking up an EMA-PT30C portable surge protector
Old 07-23-2016, 08:29 AM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Might not be really helpful but I was able to install a hard wired unit in my 07. It's between incoming power and circuit breaker box. All incoming power goes thru it. My AS might have more space, no clue with yours. I do like the hard wired version. Not exposed, not an extra plug contact to deal with.
As they say YMMV. your mileage may vary.
Welcome to Airforums by the way.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
surge protector pip8688 Batteries, Univolts, Converters & Inverters 15 08-09-2010 05:14 AM
