Old 05-17-2014, 09:13 PM   #43
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Ah, hang on, I don't have the Progressive, my bad. I have the 30 Amp versions of these, from Technology Research:
http://www.amazon.com/gp/product/B002OUVL6G
Amazon.com: Technology Research 10176 30 Amp Voltage Regulator: Automotive
Maybe the Progressive product is better!
Old 05-17-2014, 10:30 PM   #44
time2play's Avatar
2013 30' Classic
Kent , Washington
Silvery Moon, thanks for the clarification!
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 05-18-2014, 12:40 AM   #45
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I thought about putting a hardwired surge protector in our 25FB which would have required removal of the queen bed and the plywood sheet under it to place the unit as close as possible to the service entrance.
A surge protector is like the sacrificial anode on a boat in that it goes or dies rather than the electronics or motor. I elected to go with both the 30 amp (for the generator or older trailer parks as I had it for the 25FB with 30 amp service) and 50 amp portable units so if they do their job, I do not have to tear the trailer apart to replace them.
The links below are just information links for these two models which are available at Camping World and other RV equipment stores.
Portable 30 Amp RV Surge Guard by TRC - 34730
50 Amp Portable RV Surge Guard - 34750
If one wants voltage regulation as well, then there is a transformer and capacitors inside a heavy box to regulate the voltage within certain parameters. Too low voltage can burn up compressor motors on air conditioning units. Here are information links for voltage regulators and I have seen them at Camping World:
Surge Guard 30 Amp Voltage Regulator
Surge Guard 50 Amp Voltage Regulator
The common thread is that the 50 amp rated equipment is priced much higher than the higher capacity parts actually cost for more profit.
Old 05-18-2014, 07:13 AM   #46
Rivet Slave
Rocinante's Avatar
Thanks, Switz. Something went wonky with my amazon link for the Surge Guard. You got them all correct on yours. trying again for a link to the 30 amp TRC surge guard on AMZN:
Surge Guard 30amp Portable Unit with LCD Display
by Surge Guard RV Power Protection
Link: http://amzn.com/B008EUEOY6
Rocinante is our 2014 International Signature 27FB
Surge Protection nickmeloy Batteries, Univolts, Converters & Inverters 21 10-24-2017 12:06 PM
Power surge protection Mifair On The Road... 9 04-04-2012 09:42 PM
Surge Protection? Aquabud Batteries, Univolts, Converters & Inverters 3 07-18-2011 10:22 PM
Surge Protection willyd Batteries, Univolts, Converters & Inverters 0 06-24-2009 01:38 PM
surge protection, electric maintenance markjoandall Batteries, Univolts, Converters & Inverters 0 08-06-2003 08:06 AM
