Old 05-02-2014, 07:59 AM   #15
2019 30' Flying Cloud
Homosassa , Florida
I have a 50 amp external and use it every time we are out. I do have a lock and bicycle cable that I secure it with.
Sent from my SCH-I545 using Airstream Forums mobile app
Tater is offline   Reply With Quote
Old 05-02-2014, 08:52 AM   #16
2014 27' FB International
Macon , Georgia
Originally Posted by Seymour1971 View Post
Roadtech -
I have the HW30C - 30 Amp Hardwired System and have never had an issue. Installs in 30 minutes.
Seymour1971, where did you install yours?
Roadtech is offline   Reply With Quote
Old 05-02-2014, 09:21 AM   #17
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
FYI Progressive surge mod from Generator
I have the Progressive's 30amp portable with led display , I talked to the a rep. @ Progressive and she sent me this file mod I need to do when running my Yamaha generator inverter 120 volt output (the plug ties the neutral and ground together). E( MS-PT30C
File Type: pdf Special Generator Pigtail Instructions.pdf (170.9 KB, 72 views)
LAWBC is offline   Reply With Quote
Old 05-02-2014, 11:27 AM   #18
2020 Classic 33 on order
Box Elder , South Dakota
And why would you need to make that change? Specifically if you have a built in Surgeguard and are hooking the regular 30amp cord to a standard to prong adapter?
Gary
2020 Classic 33 Twin on order
NØVPN
ghaynes755 is offline   Reply With Quote
Old 05-02-2014, 03:11 PM   #19
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hmmm. I was under the impression the Progressive surge protector was not to be used with generators?
Old 05-02-2014, 09:23 PM   #20
LAWBC's Avatar
And I probably won't use the surge unit with my generator.
Old 05-05-2014, 07:39 AM   #21
Macon , Georgia
I have looked at my 2014 27FB International and I can't find a good place to mount a hard wired unit. I would be interested in hearing from anyone with a similar Airstream as to where they installed their hard wired system.
Old 05-06-2014, 08:05 AM   #22
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Have the portable 30amp Progressive with a bike lock to encourage good citizenship. Other than leaving locked to the pole (UPS, ranger's bolt cutter, and a new lock solved that), it just sits there which is good by me. Full timing, we stop at all manner of places and haven't had any power problems, but with a load of electronics for work on the road, figure it's cheap insurance. Surge is one element, but if the voltage is too high or too low, (according to spec) the unit records the error on readout and never powers to the AS. Hopefully, it will continue to do nothing and the two minute pause while it samples power source before powering through is a reassuring reminder that, it in fact, is working.
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 05-06-2014, 08:17 AM   #23
richw46's Avatar
Lexington , Kentucky
No special protection needed
I emailed Progressive about needing to add anything protective to the portable unit while it's hanging on the pole. I specifically asked "is there anything I need to do to protect the SSP30 from rain and dirt or is it fully sealed?"
I received a reply
You do not need to do anything else"
Thomas E. Fanelli, President
Progressive Industries
414B Airport Boulevard
Morrisville, NC 27560
I think that says it all
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-06-2014, 11:02 AM   #24
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I chose to hardwire my surge for a different reason than I've seen mentioned so far.
I've replaced two cord ends on my shore line so far. Not a big deal, plenty of cord.
But the stubby short leads on a 30A pedestal mount look almost impossible to replace a plug on.
Neither or the replacement plugs was burned to failure, just cooked a bit from damaged outlets.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 05-08-2014, 05:28 AM   #25
Sal44's Avatar
2012 27' FB International
Davie , Florida
I hard wired mine under the wardrobe cabinet. This only protects your side plug in and not the front one. I find I have never used the front one anyways which I suppose would normally be used for the generator. This hides the surge protector but allows easy access to it as well.
Sal44 is offline   Reply With Quote
Old 05-08-2014, 07:52 AM   #26
Macon , Georgia
Thanks for the suggestion. I have the 50 amp version, so I don't have a front plug, so this should work fine for me. Do you have the remote monitor? If so, where did you mount it?
Old 05-08-2014, 09:10 AM   #27
Sal44's Avatar
Davie , Florida
I have a built in displayClick image for larger version
Name:	ImageUploadedByAirstream Forums1399561821.283899.jpg
Old 05-08-2014, 09:48 AM   #28
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I have the remote monitor. I mounted mine in the cabinet under the sink. Easy to look at when I first hook up or if I am having a problem with AC. But not out where I have to watch the monitor blink continually.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Surge Protection nickmeloy Batteries, Univolts, Converters & Inverters 21 10-24-2017 12:06 PM
Power surge protection Mifair On The Road... 9 04-04-2012 09:42 PM
Surge Protection? Aquabud Batteries, Univolts, Converters & Inverters 3 07-18-2011 10:22 PM
Surge Protection willyd Batteries, Univolts, Converters & Inverters 0 06-24-2009 01:38 PM
surge protection, electric maintenance markjoandall Batteries, Univolts, Converters & Inverters 0 08-06-2003 08:06 AM
