Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 01-05-2005, 02:38 PM   #1
Success! Univolt Repaired.
After researching this site for awhile, I decided to try and repair my dead Univolt. I acquired three 450 v. capacitors from a local A/C supply business and replaced the 650 v. originals. The told me at the A/C business that you cannot reduce the size of the capacitors, only increase the size. But, for 12 bucks and change I was going to try anyway. Well, the once dead Univolt immediately hummed to life after soldering in the new capacitors. It cranks out 12.8 volts which I think will be sufficient.
68LANDYACHT is offline   Reply With Quote
Old 01-05-2005, 02:54 PM   #2
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Capacitors
They were refering to the capacitance in microfarads. As long as you installed the correct value, the only concerns are the ruggedness of the housing (metal can) and the voltage rating. The maximum voltage seen by the capacitors is the peak-to-peak value of the 115 VAC, which is a lot less than the 450 V that yours are rated for. $8 for a couple of capacitors sure beats $200 for a new power supply.
sander17 is offline   Reply With Quote
Old 01-06-2005, 09:19 AM   #3
1975 24' Argosy 24
Burlington , Ontario
Univolt repair
The transformer produces 6 VAC and that is supplied to the rectifier diodes. But there is in the circuit the cpacitors which turns it into a voltage doubler circuit....hence 12 V pulsin dc. the battery acts as a filter cpacitor stoing voltage to produce smooth DC Volts. This is a comm0on failure and your selection of 450 V cpacitors was sufficient to work.
I have done this on several units brought to my shop.
Rae Electronic Service Lab
raebaker06 is offline   Reply With Quote
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 10:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
