Old 09-09-2016, 05:46 PM   #1
2012 25' Flying Cloud
Tacoma , Washington
Stove Vent Fuse Blowing
Was running the stove vent and light and the 1.5 amp/250 Volt Fuse Blew replaced the fuse and it blew for the second time. Anyone having a similar problem ? Is that the correct fuse ?
Thanks for your Help in advance
BigGrey is offline   Reply With Quote
Old 09-09-2016, 07:22 PM   #2
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Are you sure it requires a 1.5 amp?
Seem kinda small imo.
15 amp maybe?
Al Boondy is offline   Reply With Quote
Old 09-09-2016, 07:26 PM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
There is a whole thread on this issue. The fuse that's in there is Italian. Just like the range hood. It is basically unobtainable in the US. Airstream suggest you go to the next larger size. Sorry I don't remember exactly what that is, but this has been an ongoing issue for anyone with the Baraldi.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 09-09-2016, 07:40 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Current fuse rating is 3.15 amp, and is available from most Airstream dealers.
Old 09-09-2016, 08:08 PM   #5
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
As one of my colleagues used to say after the third blown fuse in gear being tested on the bench "looks like ya got a box of bad fuses!" If the 3.15 amp fuse blows you might have a shorted motor winding or pinched and grounded wire.
SuperTrouper is offline   Reply With Quote
Old 09-10-2016, 01:39 PM   #6
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
250 volt/1.5 amp equals 120 volt/3 amp. look up that Brandli fuse thread mentioned above. Ace hardware carries the 3+ amp/120 volt short little fuse.
Howard L. is offline   Reply With Quote
Old 09-10-2016, 03:01 PM   #7
2007 22' International CCD
Uh, no. That's not how fuses work.
The 250 volt part of the rating is the voltage the fuse will interrupt safely. It has to do with arc safety.
The current is the same for any voltage rating.
Old 09-11-2016, 10:40 AM   #8
Howard L.'s Avatar
San Antonio , Texas
No argument, my mistake. In fact it does not matter if fuse is a 250, 120 or even less voltage as long as it is more than 12 volts--Vent hood operating voltage. Probably of more concern is that the hood uses a AC fuse and not a DC. I guess at 12 volts that is not much of a safety factor. Still, the 1.5 amp factory fuse seems too small to carry the load reliably.
power jack keeps blowing fuse? Jetset Jenna Jacks, Stabilizers, Lifting and Leveling 6 08-01-2009 11:38 AM
Fuse blowing and sparking! Lily&Me Batteries, Univolts, Converters & Inverters 7 07-27-2009 02:18 PM
Fuse #1 keeps blowing Z33 Electrical - Systems, Generators, Batteries & Solar 12 12-16-2006 09:43 AM
Parking light fuse blowing andyfuson Tow Vehicles 7 07-26-2006 06:54 PM
Brake Light fuse keeps blowing BW_LandYacht36MH Land Yacht/Legacy Motorhomes 3 08-25-2005 01:25 PM
