Old 03-09-2005, 10:14 AM   #1
AirConditioner's Avatar
Still Seeking S/T/T Light Can
Still seeking replacement 4" STOP/TURN/TAIL lamp cans for my '72 Overlander. Original insert black steel can has rusted out and can't find any major provided that makes one sized to fit the A/S original aluminum assembly - very tight fit. The present ones are only an inch deep with a bulb socket at the base, and a surrounding ring that accepts a screw-on red or clear original lens (Grote or Truck-lite OEM). Any ideas??
AirConditioner is offline   Reply With Quote
Old 03-09-2005, 03:55 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Inland-Andy has them on his website...or had them. I'm pretty sure I saw him comment in a similar thread a while back that they don't make them anymore.
odd, though, that you can get the lenses. just not the cans....
there were some that popped up on e-bay a few weeks ago. the whole taillight assemblies. they wound up going for more than I wanted to pay. (I only need 1, for a backup light...which means I really don't "neeeeeed" it at all. would be nice to have.).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 03-10-2005, 01:52 PM   #3
4 inch tail light
We are still trying to find a replacement tail light and back up light for the ealy 70's trailers.
LED's would be the real answer, but they are all to large.
They say they are 4 inch when in fact they are 4 1/4 inches.
The original metal cans are 4 1/8 inch.
If you cut the 4 1/4 inch body down, you destroy the light.
Back to the hunt, we go.
Old 03-10-2005, 05:29 PM   #4
Can-do
Thanks Andy. I'm seriously thinking about finding a 4 1/8 inch stamped can and using/making an off-set adapter/extender ring to accomodate the extra 1/8 of the LED lamp. I've tested this increased diameter and offset with a 4 1/4 lens, and it does just work. If the lamp housing is extended about 2" out from the original lens point the aluminum housing is wide enough at that point. The offset is not apparent from 20' back and I could live with it.
Since I also need to repair the Backup lamp cans, another option is to do the above and install incandescent sockets for both the S/T/T and the Backup lamp. I also want to install a third brake lamp (LED) either in the rear window, or just above it. I'll be happy to share my outcome with you and Corky.
Old 03-10-2005, 05:37 PM   #5
Air Conditioner.
We are also trying to find a can thats 4 1/8 inch, but so far, no luck.
Just today, we recived a cheap LED tail light, that needs to be cut down.
We will try that and see what happens.
We also are toying with the idea of making a fiberglass can, installing a socket and using the present lenses.
All under Corky's supervision, of course.
Old 05-10-2005, 07:21 AM   #6
Pet Sitter Extraordinaire
kposey's Avatar
1975 27' Overlander
Chattanooga , Tennessee
Images: 56
Light Socket
I have a tail light socket that needs to be replaced. Can you can replace the socket or do you have to replace the whole thing? If you can just replace the socket, what is the best way to do it?
Thanks!
Kathy, Tommy, & Crew, Chattanooga, TN
Air #2757
1989 SquareStream (Annie #8)
kposey is offline   Reply With Quote
Old 05-10-2005, 07:37 AM   #7
Thanks!
Kathy,
Have you tried Colaw's RV Salvage in Missouri or Arizona RV Salvage? There are also a good number of them elsewhere. I have a link for a site that has a ton of RV salvage yards, I just have to dig them up.
Anon is offline   Reply With Quote
Old 05-11-2005, 09:19 AM   #8
kposey's Avatar
1975 27' Overlander
Images: 56
Tail Light Replacement
I have heard from Andy at Inland RV and the whole thing has to be replaced. My question now is, how do you get the light compartment out and put the new one in?
Air #2757
Old 05-11-2005, 09:27 AM   #9
Kathy.
Removal is easy.
Take the red or clear lens off.
On the back side of the can, you should see 2 pop rivets.
Drill them out, and carefully pull the can forward, towards you.
Mark the color of the wires, and then disconnect them.
That's it. Done.
The replacement LED tail lights are mounted with double sided tape.
After they are mounted, you can put a small bead of Parbond around the circular edge.
Old 05-11-2005, 09:30 AM   #10
kposey's Avatar
1975 27' Overlander
Images: 56
Thanks Andy. I'll be placing that order soon!
Air #2757
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 08:52 AM
Hitch light plugs ALANSD Brakes & Brake Controllers 4 10-12-2002 09:04 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
