Old 11-09-2006, 05:54 PM   #1
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Lightbulb Stealth Loads
The furnace is off, the lights are off and the water pump is off. You think nothing's draining the battery. We all know the propane detector, clocks and the memory settings on the radio all consume a minute amount of power, but these loads will add up over a long boondock or storage. While preparing to leave for the weekend, the refer was switched to gas and shore power disconnected. While loading the freezer, I noticed a small rocker switch behind the freezer door under the fridge control panel. It was for climate control, similar to the switch in the home fridge that says to turn on if moisture appears on the outside. Turns on a heating element on the cabinet edges where the doors seal. I turned the switch off and noted the digital dc voltmeter went up by 1/10th of a volt. Need to remember this next time battery conservation is required.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 11-09-2006, 05:57 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Good catch, every little bit helps.
Fyrzowt is offline   Reply With Quote
Old 11-09-2006, 07:13 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Don't forget the 12volt control panel on the fridge. I know for a fact the LP dectector will totally drain a battery in less than a month
Aaron
WBCCI #XXXX AIR #2495
Solar vs generator vs nothing? Xray Generators & Solar Power 46 08-22-2006 06:06 PM
New Argosy Owner balrgn All Argosy Trailers 13 03-06-2005 04:40 PM
has anyone measured phantom loads? soultrip11 Electrical - Systems, Generators, Batteries & Solar 2 02-24-2005 08:21 AM
Solar and the Disconnect Switch/Charging/Phantom Loads Xray Generators & Solar Power 9 01-23-2005 11:55 AM
Stealth safety equipment? Stefrobrts General Interior Topics 8 04-18-2004 06:13 PM
