Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-13-2015, 01:20 AM   #1
1964 19' Globetrotter
eagle , Idaho
starting over on electrical. where do i start?
I tore out all the electrical
because some was not working
what do i need for surge protection
amps, indcators, displays, etc
any help would be appreciated. i'm going to get an electrician to help with the set up, i just need to know what I need to get started.
thanks,
idahoair is offline   Reply With Quote
Old 05-13-2015, 02:54 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
thanks,
I think that you should find a qualified (preferably certified) RV or marine technician with an extensive background in electrical installations. You are NOT wiring a house, which is what the majority of electricians are trained for. An RV is a whole different ball game...........
Old 05-13-2015, 04:22 AM   #3
1979 23' Safari
Wayland , New York
A little more detail, when you say all the electrical, do you mean ALL the electrical, 120v AC and the 12v DC.
Old 05-14-2015, 05:13 PM   #4
eagle , Idaho
electircal
well the wiring is still in place we want to put in a an updated amp converter convert lights to led
new pump
and put in some fans/vents
wire lights/trailer connection
Old 05-15-2015, 02:59 PM   #5
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Sounds like the bulk of your work is on the 12v side. Easy enough to do.
Anything "new" on the AC side I would recommend a good RV electrician. A girl was electrocuted on a local lake when she grabbed the accommodation ladder from the water. The Genset was working great, it wasn't grounded properly, and the little girl completed the circuit. It was a DIY deal. It's all straight forward, but must be done correctly, especially with the AC side. If the Electrician will let you observe what he is doing, you can pick up a lot of good skills. You have to know when to ask, you can NEVER guess, and it must be safe.
Have fun and hope it turns out better than you hoped for.
NavyCorpsman is offline   Reply With Quote
Old 05-22-2015, 08:31 PM   #6
JJA
Missoula , Montana
I have the same question as idahoair. I've been to three large RV service places and get a similar response at each, "we don't design electrical systems here." They want me to bring in components and they'll recommend replacements but I'm doing a frame off and starting with a completely blank slate. I wonder if maybe some of you experienced folks might know an RV electrician that I/we could hire over the phone to design our system and then get someone local to install?
JJA is offline   Reply With Quote
Old 05-22-2015, 09:06 PM   #7
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I just reworked most of the wiring in my MH. Whether you do the work yourself or hire a tech I highly recommend you get the book 'Managing 12 volts' by Harold Barre.. I got mine from Best Convertors. Best $20 I ever spent. My copy is well worn and dog eared.
Gregsch is offline   Reply With Quote
Old 05-23-2015, 09:25 AM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello idahoair. It sounds like you are doing a significant upgrade to your vintage trailer. Airstream was a pioneer in the "univolt" system where ALL the appliances and lights ran on 12v. This allowed you to be boondocking in the heart of Africa while running the comforts in your trailer off the batteries.
Your trailer has three distinct electrical systems. 1. Exterior lights and brakes and a battery charge line all powered by your tow vehicle when you hook up to tow. 2. The 12v system which is basically everything in your trailer except the AC. A key component in the 12v system is the converter that converts 115v AC to 12v DC. This allows you to charge the battery and use your 12v system while plugged into "shore power". 3. The 115v AC system mainly is the household outlets mounted in the walls plus a line for the AC. The AC system is mostly a 30 amp system providing about 3000 watts of AC power to the trailer. The AC will pull about 1800 of those watts when it is running. Plug in a 1500 watt hair dryer and you might pop the circuit breaker.
Surge protection helps protect your sensitive 115v electronic gear from voltage spikes from the grid. I don't use one, but there are just a lot of people who do. A lightning strike at your house is likely to ruin your computer, TV, stereo, and other electronic circuit boards.
The main "indicator" you might like is a battery voltage readout. Then you know when your batteries are fully charged, and when they are not.
So things for you to consider:
Find a good converter. It is the heart of your system. There are many on the market.
Consider a new AC "breaker box". New breakers may be more reliable. Upgrade one of your circuits to ground fault interrupter, or GFI. These breakers are very sensitive to voltage leakage to ground. They prevent shocks if the ground circuit gets compromised. The outlets in the bathroom, kitchen, and outside the trailer ought to be GFI protected.
Consider upgrading your 12v fuse panel.
Consider two 6 volt "golf cart" batteries and a solar panel if you plan on a lot of boondocking. The solar panel will keep the batteries charged on a sunny day. Two 6 volt batteries have more storage capacity than one 12v battery. Remember how quickly your car battery goes dead when you leave the lights on?
My intent is to help you with some of the basics of the Airstream electrical system. I hope it helps a little.
David
Old 05-23-2015, 10:02 AM   #9
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
Electrical work can be intimidating when you look at the whole complex system, but if you break it down into little pieces it's really not that bad. For example say you wanted to upgrade an old water heater to a new one with direct spark ignition. They need 12v to run. Most diyers would be comfortable adding that circuit to there trailers 12v system. There are books and online resources to help you figure out wire size and circuit protection. Like anything the most important thing is a good foundation. The battery, charge converter, power distribution box (fuse box), and system ground (to the shell and chassis) is that foundation. Take your time choosing and installing these components and the rest will fall into place really easily. Good luck and there are lots of good books out there.
bellastream is offline   Reply With Quote
Old 06-17-2015, 07:19 PM   #10
eagle , Idaho
thanks for the info all.
gives me a good starting point.
Old 06-23-2015, 10:21 PM   #11
vidalia , Georgia
subscribing
Glt12 is offline   Reply With Quote
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 09:47 PM
OK, do I have to start over? dznf0g Off Topic Forum 23 11-14-2010 05:42 PM
Over kill, or just over the top! airjeff Tow Vehicles 12 07-22-2010 11:13 PM
Starting over? propstrike Airstream Motorhome Forums 29 08-06-2006 08:14 PM
Starting over with the plumbing Marc Marenco Plumbing - Systems & Fixtures 11 07-06-2003 06:35 PM
