Old 08-30-2015, 12:16 PM   #1
1967 28' Ambassador
New orleans , Louisiana
Starting from Scratch - Help!
Hi everyone, newbie here..
I have completely gutted and am rebuilding a 1967 Ambassador Double. When I got it it didn't have a battery, and since I'm going to be having to purchase a new one anyways I feel like going all out. I'd love to incorporate solar panels to get a system where I can boondock for days at a time, but there is such a wealth of information out there about this that I feel overwhelmed slogging through it. Is there somewhere that I can find a specific list of things that I need to buy? Like a starter kit? Theres so many options for each specific component, the inverter, the battery, the panels - I'd just love to be able to run down a list and get things instead of losing my mind in all the research/options.. Can anyone help a lady out??
My intentions for the airstream are to make it my home for at least a year. I"m into living off grid but I'm not naive about how the lack of long hot showers/community might make me a little crazy, so I know that I will be spending plenty of time at campsites or staying with friends/family. I'm looking for a good reliable solar set up, but I'm not trying to Mad Max it over here.
Also, I haven't bought an RV fridge (the one it came with is a residential dorm fridge), or AC so if there are better/worse options for those in relation to a solar set up I'd love the advice! I"ve read that the Domectic and NOrcold refrigerators break a lot, and I may be better served just going with the residential one and getting an inverter for it..?
Thank you in advance for all advice!
Shannon
Shambles is offline   Reply With Quote
Old 08-30-2015, 01:52 PM   #2
mandolindave's Avatar
You could talk to an expert at Amsolar
Tech Support 541-255-0630.. They have packaged system and can cater to your particular needs and budget.
The propane powered fridges are the way to go. They work for months on a single tank. An affordable solar system would struggle with the power needs of an electric fridge
mandolindave is offline   Reply With Quote
Old 09-01-2015, 01:49 PM   #3
gator.bigfoot's Avatar
KW , Ontario
There is no way you are going to be able to run AC off grid without a big generator or more solar cells and batteries than your trailer can carry.
for solar check out this link https://handybobsolar.wordpress.com/...-other-things/
This guy lives full time off the grid and has lived for extended time in an RV. So you hopefully you can come away with some good tips here.
gator.bigfoot is offline   Reply With Quote
Old 09-01-2015, 02:16 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
ABSOLUTELY NOT TRUE!!!!
A 400 amp/hour lithium battery and Magnum 3000 hybrid inverter will start and operate a Dometic 15K heat pump for roughly 3 hours with no other energy input.
Couple that with a 2000 watt generator and you can run the A/C all say if you like.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 09-01-2015, 02:45 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Lew Farber
Could this be coupled with solar panels for those time no AC is needed?
And, what would be a ballpark cost, from scratch? (without the generator)
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 09-01-2015, 03:12 PM   #6
lewster's Avatar
All of the systems I have installed using this new technology have had 400-700 watt solar arrays and the required solar charge controllers as a central component.
Please PM me for more information.
Thanks!
Lew Farber
541-490-6357
Old 09-02-2015, 01:09 PM   #7
Silvr_Lining's Avatar
2018 Nest
San Rafael , California
Re Solar set-ups
Solar is more than amps and watts. You need to know that Depth of Discharge (DOD) significantly affects the life of your batteries. As a generality, 50% DOD is usually considered max. Solar is a poor source for large power sources. It is a great supplemental power and can run light loads (lights, computer, etc.) for sustained periods with sunny weather. I do not believe it should considered a power source for AC or large power loads. You will be disappointed. Solar is not cheap either. A well thought out system will be a great asset, but don't forget that gen set!
-Marc
Silvr_Lining is offline   Reply With Quote
Old 09-02-2015, 02:25 PM   #8
Mission , Texas
Good reading here ...
http://amsolar.com
I'd get a 3 way fridge.
nrgtrakr is offline   Reply With Quote
Old 09-02-2015, 03:44 PM   #9
lewster's Avatar
Welcome to AM Solar_Your RV Solar Specialists since 1987
With solar, I'd forget the poor performance and efficiency of ANY gas-absorption type fridge and go straight to a Danfoss compressor powered marine fridge.
Indel Webasto:*CRUISE Marine Refrigerators
OR
seaclassic
I use both of these on a regular basis in my installations to great user reviews!
Old 09-02-2015, 04:38 PM   #10
Mission , Texas
Awesome ...
Old 09-02-2015, 08:16 PM   #11
lewster's Avatar
-Marc
True for lead based battery systems. Lithium iron phosphate batteries are a whole new world. There is no disappointment with a properly designed, sized and installed solar charging system and a lithium battery large enough to suite your needs.
Since lithiums can be drawn to a minimum or 80% depth of discharge (DoD) and exhibit little to no voltage sag, even under very high amperage loads (no Peukert Effect), they are a game changer when discussing the use of battery power for air conditioner operation.
This is especially true when coupling a minimum 400 amp/hour lithium pack with a Magnum MSH3012-M 'hybrid' inverter/charger to a Honda or Yamaha 2000 watt generator, which will seamlessly supplement the output of the genny to start and operate a roof A/C with no effort. This combo will continue to work as long as you like to run the single generator with minimal draw from the battery.
The only limiting factor is the depth of your pockets (DoYP)
Old 09-02-2015, 08:53 PM   #12
1979 23' Safari
Wayland , New York
quoting lewster, "The only limiting factor is the depth of your pockets " as with everything else airstream
"I'd love to incorporate solar panels to get a system where I can boondock for days at a time"
I think for this a few hundred watts of solar and a few deep cycle batteries, a good solar controller, converter, and inverter would do you well. And taking boondocking to heart; which to me means no AC and no microwave and thinking of the AS as a big shiny nice tent.
If you're going to be starting from scratch though I'd consider a solar charger and converter that are lithium ion capable so if you decide to get LIPO batteries you don't have to get new ones. Them LIPO batteries ain't cheap though!
Old 09-02-2015, 09:01 PM   #13
1979 23' Safari
Wayland , New York
I'd give bestconverter and amsolar and lewster calls.
I'm not sure if LIPO converters can charge lead acid as well, it would be nice if there are selectable units.
Old 09-02-2015, 09:18 PM   #14
lewster's Avatar
All of the Blue Sky solar controllers and Magnum inverter/chargers are fully programmable for use in either lead based battery banks or lithiums. I use them in ALL of my installations, regardless of battery type........just different programming.
Old 09-05-2015, 07:01 AM   #15
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
OR
seaclassic
What would your ideal battery setup be for one of these big boys? I'm trying to revive my old Dometic with various vent fans... if that doesn't work, I'll be in the market for a new fridge. The SeaClassic 8.1 draws over 5 amps, that seems like a nightmarish load to a guy with a single deep cycle!
SuzyHomemakr is offline   Reply With Quote
Old 09-05-2015, 09:54 AM   #16
lewster's Avatar
I only use these types of fridge units when there is a sufficiently large solar array and battery bank in place. That means a battery of at least 300 amp/hours and the solar to charge it.
The 5 amp rating that you see listed is at 100% duty cycle. It has been the experience of many of my clients that the actual draw from a fridge powered b a Danfoss compressor is more like 40-50% of the rating, as the unit does not operate continually.
With that in mind, a 5 amp rating would turn into a 2-2.5 amp/hour draw. Over the course of 24 hours, that would be about 60 amp/hours max. Any properly designed and installed solar charging system will replace that amount of power easily, usually by early afternoon.
Old 09-05-2015, 10:16 AM   #17
2014 30' Flying Cloud
Ponce Inlet , Florida
I have and indel isothem 195 with dual danfoss compressors. We love it. It draws just short of 8 amps DC with both compressors running. We have found the 76 ah @ 70F per day spec indel published is a good approximation.
The most I have used overight was 110 Amps. That was at Lee's Ferry AZ where the day time temp was 104 and it got to a balmy 81 at midnight. Normally I use about 60-70 Amps overnight for all our elecrical needs. From my experience you would need a minimum 200 ah battery if you plan to use a genset to charge every AM.
If your going with solar you will need a much larger battery bank. For solar it depends on how you plan to camp, how manny consecutuve days you want to dry camp, what time of year and where you camp, type of batteries and a host of other variables.
We designed our system for around 4 days of crappy weather or partial shade.
4 135 watt Solar panels Watts with
Lifeline 600ah battery bank.
We have dry camped for 16 day in mostly sunny sites for 16 consecutive days with no issues.
We have also been in crappy weather w/ partially shaded site and made it four days but were close to 50% capacity. Probably would not have made a fifth night. Overall the system exceeded our expectations.
Because everyone's electrical needs are different there is no set answer.
Based on my experience I would not get less than a 400 ah battery bank larger if you have the space and $$. You could get less if you go with lithium batteries.
YMMV
Benn
Beach Bum is offline   Reply With Quote
Starting From Scratch AV stowaways Audio, Video & TV 4 08-07-2011 03:11 PM
Starting from Scratch Mike&Ali Electrical - Systems, Generators, Batteries & Solar 12 02-26-2010 10:42 PM
starting from scratch~moho vs. trailer? ~flutterbee~ Buyer Guidelines 14 07-14-2006 08:48 PM
Rewiring - starting from scratch 59er Electrical - Systems, Generators, Batteries & Solar 32 10-26-2005 04:20 PM
