Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-01-2013, 11:39 AM   #1
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Stange noise from the fridge.
We have a newer Dometic RM2820 that is "clicking" every once in a while. It's not constant and comes and goes. Seems louder in the coach, but could be the echo-chamber effect of the interior. It will click once or twice, then quit for a while. The fridge is keeping temp, but this is starting to drive me up the wall. Any clues?
Mike Leary is offline   Reply With Quote
Old 09-01-2013, 11:41 AM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
Propane igniter?
— David
Old 09-01-2013, 11:46 AM   #3
1974 Argosy 20
Kooskia , Idaho
Probably the ignitor for the propane flame. When the thermostat calls for cooling, the gas valve is opened and the spark lighter ignites the flame. Usually takes two or three "clicks" or "snaps" for the flame to light and feedback to the board to turn the spark off. It happens at random times as it is dependent on when the thermostat calls for cooling.
Old 09-01-2013, 01:01 PM   #4
mapleton , Utah
Pull the outside vent cover and put in as much sound deadening insulation against the interior surfaces as you can. should help both noise and fridge performance.
tim
rumrunner is offline   Reply With Quote
Old 09-01-2013, 01:50 PM   #5
Mike Leary's Avatar
Ajo , Arizona
All good points, thanks. Does the fridge ignitor board, even though we're on shore power, think it's on propane, causing the click?
Old 09-01-2013, 01:57 PM   #6
1974 Argosy 20
Kooskia , Idaho
It should only click on propane. Are you sure your power is operating properly? If the circuit which goes to the refrigerator is not working, you may be running on propane and not aware of that.
Old 09-01-2013, 02:06 PM   #7
Mike Leary's Avatar
Ajo , Arizona
Our lights on the fridge show we are on shore power. The switches work fine, and we took the coach out and it automatically switched to propane. The fridge is three years old. I have heard the "click" when we're boondocking on propane; this is a different, more metalic click-thunk.
