Old 08-04-2007, 10:14 AM   #1
richinny's Avatar
2011 34' Classic
splitting off a/c or microwave 1994 34' Excella
has anyone done this? currently the trailer is used stationary in an RV park with 120v AC available. The park has a 50A and two 20A outlets. the setup now is that the 30A trailer line plugs into a 50A adapter and the 15A outlets are unused. does the roof top AC have a regular plug on it that i can plug directly into one of the 20A outlets? is there an easy way to run a line from the microwave/convection oven to the outside? in the florida heat, things heat up before i get done cooking. *whine*
Old 08-04-2007, 11:50 AM   #2
Dwight's Avatar
1999 34' Excella
Joshua , Texas
elect service...
You have at least 2 options; one option is to add a priority switch so that either the microwave or A/C is the master, the other option is to change out your existing breaker box to a larger one and wire it for 50amp service. I recently did the later option on our trailer and it works great.
Dwight
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 08-04-2007, 06:27 PM   #3
richinny's Avatar
2011 34' Classic
changing to 50A does sound best.
besides the box and cable, what wiring is required? any idea of the cost?
thanks!
Old 08-04-2007, 07:05 PM   #4
Dwight's Avatar
1999 34' Excella
Joshua , Texas
parts....
I got the new breaker box (about $15) at Lowes as well as the new breakers. I bought a stainless steel Marinco socket (about $175) for the rear of the trailer on-line. I only had to run an extra length of Romex from the socket to the new breaker box. So for less than $200 - $250 you can do it yourself.
Old 08-04-2007, 08:18 PM   #5
richinny's Avatar
2011 34' Classic
i have the overhead switch in the overhead storage that flips between ac and microwave. it would seem that i need to run a seperate line for the microwave to the breaker box.
Old 08-04-2007, 09:05 PM   #6
Dwight's Avatar
1999 34' Excella
Joshua , Texas
switch...
That is called an "either or" switch. I bet that if you look at your breaker panel or wiring diagram, that you will find both appliances are on one circuit which is why you have the "either or" switch. You may be able to separate them and add a breaker if you have a space or spare in your breaker box.
Old 08-04-2007, 09:46 PM   #7
richinny's Avatar
2011 34' Classic
ok, the trailer and diagrams are resting in florida so it will be a while before i get to tackle it. i'll be adding it to my 'winter' list :-)
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
