Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-31-2010, 01:51 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Source for unusual electrical outlets in late model classic
I went to the home center and bought a replacement outlet for my traylah. I wanted to replace the outlet closest to the door with an ivory, rather than white, one.
Upon disassembly I discovered that the traylah has these curious, insulation displacement, no outlet box required, outlets that are different from anything at the home center.
Anyone know where I can get an ivory one? I'm trying to get all the ugly out of my traylah, and the white doesn't blend into the woodwork the way I want.
Old 08-31-2010, 02:11 PM   #2
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
I have standard outlets in my 1967 Airstream and like yours no outlet box. Maybe someone put something different in yours. It would not be a ground fault outlet would it? Most outlets need to have a terminal for ground, white, and black.
Silver 67
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 08-31-2010, 02:19 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
They look like these, which I found after I posted:
Self Contained Receptacle Ivory - $6.99
I have had problems with timely shipment from that vendor however.
Old 09-04-2010, 07:44 AM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
Shallow socket
Jammer,
The receptacle you found may work. They are pretty hard to work with. If it is in-line with other receptacle then the wires are skint back and run all the way through. They can be hassle to get the back cover back on.
Home centers have a blue shallow 110 box that will work in most RV. I know Lowes carries it. I have always found it much easier to work with.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 09-04-2010, 07:47 AM   #5
Dan@LED4RV's Avatar
get two
Jammer,
If you decide to go this Self Contained way, at this price, I would get two. If some goes wrong you have a backup.
Dan
Dan Brown
Denton NC
Old 09-04-2010, 09:11 AM   #6
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Buy a "repair" box and a regular outlet and plate. They are stocked at every HD, Lowes, Furrows, etc. The repair boxes mount just like the RV recepticals mount with swinging arms on the corners. The substitute receptical will be of better quality than the rv receptical.
While you are at it, feel around in to the opening and see whether there is enough space to mount a double-width box that will give you 4 outlets. I installed a double box in my Classic 28 and keep my voltmeter and neon circuit tester permanently plugged in. I still have two free outlets. It is easy to saw out the additional width for the double box..
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 09-04-2010, 10:03 AM   #7
Mexray's Avatar
1978 28' Ambassador
Morada , California
I'm thinking a can of Ivory colored Krylon spray paint may be the easiest solution....
Ray
Ray & Pat; Morada, CA
Old 09-08-2010, 10:32 AM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
Mexray I have considered that, having applied the same solution to the heating registers.
Pahska, I believe that the opening cut for these is smaller than that used for a standard outlet box. Enlarging the hole in the plywood is potentially problematic because of the ease with which the veneer can be torn and the difficulty of repairing such damage. Not saying it can't be done, just that it is not as straightforward as it would be with drywall or something.
Old 09-10-2010, 04:33 PM   #9
Contributing Member
Pahaska's Avatar
The opening in mine wastthe same size. It is easy to enlarge it, as I did, with a small saw. I had no problem with the veneer. You would be sawing inward which is unlikely to disturnb the veneer. The outlet box covers any rough edges. I'm on the road, or I would post a photo of my cutout.
John W. Irwin
WBCCI #9632
What about a late model Suburban? connorsa Tow Vehicles 3 10-26-2007 11:03 AM
Anyone own a late model AS motorhome? idahosafari General Motorhome Topics 14 10-23-2004 12:18 PM
Late 50's drapery hdwre- got a source? millionairstream General Interior Topics 3 08-01-2004 08:28 PM
Missing Electrical Outlets gklott 2001 - 2005 Classic 2 04-21-2004 01:03 PM
Unusual Diesel Classic CBBOB Airstream Motorhome Forums 1 10-20-2003 06:45 PM
