Old 01-18-2019, 12:34 PM   #15
Independence , Louisiana
Thanks Dave! Think there was just not enough sun to keep the batteries charged!
AGB54 is offline   Reply With Quote
Old 01-18-2019, 02:47 PM   #16
Ayr , Ontario
How much solar do you have. Even with no sunshine you should get something. The only way that your not is if there is something defective or your load is exceeding your solar powers output. I have yet to plug mine in this year or last year since March. It's -10C out and I'm at 100%. The panels are mostly covered in snow at the moment, but there's enough to charge it during the times it's not. I camped 3 weeks in the summer without direct sun on the panels and it was at 100% every day. What kind of equipment do you have? How much current are drawing at the moment? What is the voltage of your system? What are the settings of your charge controller?
gator.bigfoot is offline   Reply With Quote
Old 01-18-2019, 03:24 PM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
What difference a few degrees can make...
22* vs 30*🤔
ID:	331979   Click image for larger version
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 01-18-2019, 05:37 PM   #18
Ayr , Ontario
Originally Posted by ROBERT CROSS View Post
22* vs 30*
Still doesn't mean you have 100%. Did you measure it at the batteries? The voltage seams very low for 100%.
Old 01-23-2019, 10:44 AM   #19
2008 16' International
Forest Knolls , California
Solar panels in the shade
Solar panels do not have to be in constant direct sunlight in order to keep batteries charged. I have two hundred watts on my roof to power my two six volt batteries. Even when parked in the shade, they recharge enough to carry me through normal use all day. This is plenty for my 16’ Bambi. There must Ben something wrong with your controller. I would have the system checked out. This is not normal.
RudiDundas is offline   Reply With Quote
Old 01-23-2019, 11:12 AM   #20
What is the relationship between voltage and SOC in a Lithium battery?
"the Li-ion battery, there is a very small change for voltage between each charging and discharging cycle due to the constant voltage of Li-ion battery, it is difficult to estimate the SoC by using voltage-based method."
That is why I charge at 30%.
Amanamus
"Tahawus"
Old 01-24-2019, 06:08 AM   #21
Ayr , Ontario
Measuring the SOC on a lithium is no easy task. But there are ways.....
http://liionbms.com/php/wp_soc_estimate.php
http://www.ti.com/lit/an/slyt402/slyt402.pdf
https://uwaterloo.ca/mechatronic-veh...phd-thesis.pdf
Old 01-27-2019, 01:25 PM   #22
2019 23' International
2019 Interstate Grand Tour Ext
California , Dunbar Drive San Pedro
if its new, please contact the manufacturer or the dealer of this brand. I hope they give a proper solution to your problem.
thanks
robertstaley is offline   Reply With Quote
Old 01-27-2019, 08:43 PM   #23
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Here you go. I got this from Battle Born.
DanClick image for larger version
Old 01-27-2019, 10:05 PM   #24
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Solar system not keeping batteries charged
[QUOTE=gator.bigfoot;2202833]Measuring the SOC on a lithium is no easy task. But there are ways.....
[\QUOTE]
gator.bigfoot
It would seem to me that a battery monitor will measure the SOC of a lithium battery the same way as it does for a lead acid battery. Alternatively, using the BB voltage versus SOC table you can determine the SOC of the lithium battery using a voltmeter to measure the voltage of the lithium battery.
The photos show the voltage and the SOC of my lithium batteries using my Trimetric battery monitor.
Dan
ID:	332487Click image for larger version
Old 01-27-2019, 10:48 PM   #25
DanAttachment 332486
As demonstrated on my monitor...40% soc @ 13.03v
Amanamus
"Tahawus"
Batteries - keeping them charged over the winter ajwbarnard Batteries, Univolts, Converters & Inverters 20 10-18-2017 08:09 AM
Keeping Batteries Charged While in Storage beachbouy Electrical - Systems, Generators, Batteries & Solar 20 03-01-2016 08:18 AM
Keeping Batteries Charged GLovedahl Batteries, Univolts, Converters & Inverters 4 01-31-2015 12:53 PM
Keeping batteries charged Daysailer Batteries, Univolts, Converters & Inverters 28 04-19-2012 01:02 PM
