Old 11-10-2018, 09:25 AM   #1
2019 22' Sport
Quartzsite , Arizona
Solar Repair/Upgrade Safety...
Hi,
Asked this the wrong way previously. I have worked on auto and house electrical and know the procedure BUT with a solar system always providing some sort of charge I'm not sure how to "disable" it or safely disconnect to say add a battery of a Victron monitor.
I know it's a low watt situation but perhaps the panels are sensitive and easy to short out... Obviously I have no clue and would like some direction before I just unhook the battery and or add Victron shunts etc....
Any good books or concise websites dealing with this?
Rounder44
Rounder44 is offline   Reply With Quote
Old 11-10-2018, 09:30 AM   #2
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
Covering the solar panels allows you to safely work on the solar panel output wires. Also disconnect from shore power and then remove the negative battery cables to eliminate all power sources to your Airstream. Make sure you turn off all possible loads on the battery before disconnecting the negative cables to reduce possible arcing.
2017 Flying Cloud 25FB (Miles) 218 nights 30,171 miles
400W Solar, Blue Ox SwayPro, 16" Michelins
2017 Nissan Titan XD 5.0 Cummins Diesel 4x4
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 11-10-2018, 09:31 AM   #3
1974 25' Tradewind
Calgary , Alberta
Your panels should have a disconnect breaker that you can trip to separate the panels from the controller. If you need to ‘safe’ the panels themselves, cover them up...
Alumineer is offline   Reply With Quote
Old 11-10-2018, 12:18 PM   #4
2018 25' Flying Cloud
Portland , Oregon
If it makes you feel any better the panels themselves don’t mind being shorted. In fact that’s how they measure their output current, just thrown an ameter across the wires! Now if you had a bunch in parallel you could get some exciting sparks on the trunk feeding down from the roof and, I suppose, melt some insulation if the system’s wiring wasn’t rated properly, but the panels will be fine.
Of course be VERY careful creating sparks around lead acid batteries as hydrogen is a byproduct!
daleyocum is offline   Reply With Quote
Old 11-10-2018, 01:32 PM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
With a normal RV solar setup, you are talking about a low voltage / current limited system. You can get sparks, but it's no more lethal than a 12V car electrical system (which has way more energy). With proper wire and fusing, even shorts are not going to create a hazard. As mentioned above, they will not damage your panels.
With a stock setup, pulling the fuse between the panels and the converter is the simple way to be 100% sure the system is power down.
Indeed on the other side of the solar charger, you have a battery. Even with proper fusing, you can get quite a bit of energy out of a battery. If you get past the fusing (like hit across the terminals) the current can be enough to melt things. That's the side of the circuit you should be concerned about in terms of damaging stuff.
Why bother with these distinctions? It is indeed far easier to simply say that all electrical circuits of any sort are hazardous and you must take a long list of precautions with all of them. Yes that sounds a lot easier to understand. There are a couple of gotchas. One is that it simply is not true. The next is that coming up with a procedure that treats changing a battery in a flashlight just like working on a 13KV power line gets a bit insane. Treating all electricity equally does not allow you to understand what's going on and reasonably evaluate what you should do in a given case ....
Portable solar with eye towards upgrade No.15 Generators & Solar Power 2 03-12-2016 07:35 PM
Preparing for future solar upgrade during current reno Caroyl Generators & Solar Power 16 12-11-2015 11:03 AM
Solar upgrade duckguts Electrical - Systems, Generators, Batteries & Solar 14 03-09-2015 01:27 PM
Converter,battery and solar upgrade SilverSinbad Batteries, Univolts, Converters & Inverters 2 01-19-2015 11:57 AM
Solar upgrade beerrun'r Generators & Solar Power 1 09-21-2013 04:00 PM
