Old 10-04-2017, 08:27 AM   #1
2012 25' FB Flying Cloud
Portland , Oregon
Solar panels and installation
Can anyone recommend a dealer that does solar installations in Portland Oregon? I currently have 120Watts and Zamp ZS-30A controller. I want to add an additional solar panel(s).
Hophead is offline   Reply With Quote
Old 10-04-2017, 10:02 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
How much are you trying to add?
There's only so much room on the roof of a 25'. If you are trying for a major upgrade, you probably need somebody pretty good.
uncle_bob is online now   Reply With Quote
Old 10-04-2017, 10:09 AM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Solar Dealer
Suggest you look at AM Solar down by Eugene. They started in the late 80's.
Call and talk to Dave Reuter if your interested in having them do the work or supply the components. (Don't email, they seldom respond, just call.) They have a terrific website with a lot of tutorials.
http://amsolar.com/
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 10-04-2017, 10:11 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Isn’t Lewster associated with AMSolar?
http://amsolar.com
MICHAEL
Old 10-04-2017, 10:43 AM   #5
57Vintage's Avatar
1958 26' Overlander
Images: 21
AM Solar & Lewster
If you look at his public profile he is an authorized installer for them. I'm not sure when he's leaving, but he winters in Florida. If he's available, I would have no qualms about him doing the work.
Harold & Rebecca
Our thread:
Old 10-05-2017, 12:02 PM   #6
alfred , New York
If you are mechanically inclined, it is easy to do yourself. I did mine, 3 100 watt panels (flexible panels), on my 19' globetrotter. I was 66 yrs old when I installed them. The most important thing is drilling through the body and installing the fastener joining the solar panel wires to the wiring from the battery, and making sure that is secure and water tight. Good luck!
diane
nevermoor is offline   Reply With Quote
Old 10-05-2017, 12:19 PM   #7
2015 30' Classic
Pleasanton , California
In hophead's case a DIY install if probably even easier. An extra panel can be added to the roof without drilling any holes. The panel feet can be bonded to the roof using 3M UHB tape and then sealed with Sikiflex 221. Connecting the new panel in parallel to the existing panel is probably all that's required.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 10-05-2017, 12:38 PM   #8
2016 16' Sport
Miami , Florida
This!
Call AM Solar. They will walk you through it. Carley Rocks!
Shiny16 is online now   Reply With Quote
Startup Voltage for Solar Charger and 12v solar panels ggreen63304 Generators & Solar Power 12 09-01-2017 06:58 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
Solar Panels and Refrigerators kennytheecat Batteries, Univolts, Converters & Inverters 2 01-16-2009 08:28 PM
am solar mounts and kyocera panels Yak dad Generators & Solar Power 2 06-21-2008 09:21 AM
