09-10-2010, 05:29 AM
2010 23' FB Flying Cloud
Fayetteville
, Georgia
Solar Panel Costs
If you purchase a trailer with a solar pre-wire feature, what does this include. What else, other than the panels, needs to be purchased. I inquired about getting the solar panels when I was going to buy a A/S in 9/2009 (Camping World dealership in Woodstock, GA flooded and all their inventory was lost...to include my new, delivered trailer) and they quoted me around $250. I am in the process of purchasing in the next week and again inquired about installation of solar panels and the Camping World Atlanta dealership in Oakwood quoted me a $1200 figure (for a lot more than the panel).
What comes with the solar pre-wire?
09-10-2010, 06:07 AM
1999 23' Safari
Perrysburg
, Ann Arbor
I don't know what "comes with" the factory "pre-wire" but there are a bunch of threads on here that suggest that the factory solar wiring is too small a gauge of wire to be totally effective. Voltage drop in the wire is a big deal - you want to capture every milliamp that the panels will generate, and losses in the wiring are avoidable but expensive.
In addition to the wiring (or replacement wiring), you will need the panels themselves, mounts for the panels, a charge controller (and DO get an MPPT charge controller - it will maximize your battery charge), perhaps new batteries, and most folks recommend a battery temperature sensor - so that your charge controller will send the batteries as much current as they can take without overheating.
I went to Lew Farber (Lewster on the Forums) in Florida and had him provide and install the whole shooting match with panels, etc. from AM Solar. It's worth chatting him up for ideas - he's had a solar system on his rv - repair van for years, powering his entire workshop, and he has a wealth of information. My system (two 130 watt panels and three Lifeline batteries) leaves me where I never have to be plugged in to shore power or a generator unless I need/want to run the air conditioning. You will love it, if you boondock much.
Good luck.
09-10-2010, 08:53 AM
_
Originally Posted by benjisgal
If you purchase a trailer with a solar pre-wire feature, what does this include...
solar prewire simply means there is a wire running from approximately the fridge box to the roof.
this wire is inside the wall/roof between the inner and outer skin.
if panels are attached TO the roof a hole can be cut to fish out the wire and connect.
so solar PREwire is simply a cosmetic connivence added during production.
essentially all newer streams have this.
__________
adding solar energy to an rv involves adding EVERY BIT of solar package equipment needed to the trailer.
http://www.airforums.com/forums/f448...ice-39392.html
the likelihood of spending much time OFF the grid and where are important considerations.
solar is simply a method of REcharging batteries, that is highly dependent on access to SUN.
imagine if the only water carried IN the stream was rain water?
how easy or hard would that choice make camping anywhere but a rain forest?
_________
a small generator is a LESS expensive, reliable, simpler approach to recharging batteries.
IF rv hookups are available (power/water/sewer) neither solar OR a genset are needed.
new rv'ers imagine they might speed long periods of time AWAY from connections...
seldom is this true and seldom is it part of NEWbie rv'n to the extent we might imagine.
there are full service rv parks or partial service/connections in essentially all parts of the north american content...
__________
a truly USEFUL solar setup will run 2000-4000$ installed.
while we think of it as "always on" and free from the sky...
planning the purchase, thrifty power use, keeping the SUN overhead and EXPENSE are still issues.
cheers
2air'
09-10-2010, 09:39 AM
2005 22' Safari
Hyde Park Place
, Ohio
I have a more positive take than the poster above.
I see different classes of solar system, depending on usage.
Occasional light user: usually in storage, or at a 30/50 amp hookup, but wants solar: about $200 for a 20W panel, wire and a decent charge controller - this will be enough to charge maintain batteries in storage, but will not charge them. It could also run a couple of LED lights during the *day* but that's it. $200.
Occasional heavy user: usually in storage, or at a state park or in the wilds, no hook-up. 100-200W will fully charge the batteries in a day or so of good sun, and run the 12v circuits, but you'll have to forgo the A/C. You'll be fairly self-sufficient. You'll also need a good charge controller and heavy duty wiring. $600-800 self install. $1000-2000ish for pro install.
Light boondocker: Serious about having power to be off grid. 300W+ of panels. 2 or 4 batteries. Heavy duty charger and cabling, monitoring. You watch TV and have lights blazing - all the comforts of home! (but, as always, no AC) $2500-3500 self install, $5000+ pro install.
Serious boondocker: Ironically, the serious boondocker uses far less power as they are very aware of the limit nature of the resource. They'll usually have smaller panels, and larger battery storage so they can survive a few dull days and winter, but don't demand much of their batteries. 100-150W of panels, charge controller, batteries. $1000-1500 self-install, $2500+ pro install.
Prices are guides, YMMV. Your stereotypes may vary also. How do YOU use your AS and how do you think a solar panel would change that?
TX-16
09-10-2010, 09:59 AM
_
there is nothing negative in my post...
except the implied need for + and - connections and grounding in reality.
the o.p. is not likely to DO any install,
and hasn't defined HOW the solar package will be used.
in fact MOST new buyers haven't sorted out
how the solar bits fit into their grand camping scheme.
________
by far the most bang for bucks and every day utility, especially while boondocking...
comes from the LP gas system and a couple of healthy size lp tanks.
fridge, hot water, heat, cooking and even lighting can be had simply from lp gas.
and without regard to parking IN the sun.
yes solar is can be a useful tool, but the buy IN price is still an issue.
while a lpgas or a petrol powered genset are MUCH more pay as you go...
and without much/any installation cost beyond what is ALREADY built into the stream.
_________
the op asked about PREwire, it's a simple thing really.
the "cost" of panels is entirely dependent on which panels
and ALL of that info is readily available online.
judging 1 post negatively and another positively is more complicated.
cheers
2air'
09-10-2010, 10:12 AM
Naples
Solar 'pre-wire' is just that........WIRE! And Airstream provides you with only 12AWG wire, which is way below what is necessary for almost any solar charging system.
Having installed many solar charging systems, I use a minimum of 8AWG for simple installations and 6AWG for larger (400 watts+) systems. MPPT charge controllers are a MUST, as they are the most efficient and depending on the manufacturer, provide true 3-stage battery charging, also a MUST.
Next is your battery bank. This must be sized for your intended usage, then size the solar array to keep them charged. We use Lifeline AGM batteries exclusively on our solar installations and have found them to be quickest and easiest to re-charge and provide the longest service in the field, but talking batteries here is like religion and motor oil, everyone has their own opinion and swears by what they use. We use what works for us and our customers, and we use pallet loads.
Another factor to consider is the output voltage of the panels. We use custom built 40 cell panels that are 'hotter' than most panels available. Our MPPT charge controllers use this extra voltage to 'boost' the available charging amperage seen at the batteries, resulting in faster, more complete charging.
The system in my service van has 4 X 100 solar panels and 2 X 300 amp/hour Lifeline GPL-6CT 6VDC golf cart batteries in series. This system is used to power all of the auxiliary 12VDC loads in the van (stereo, lighting, driving and fog lights and most interior power applications), rather than using the engine battery. The prime use is running a 2000 watt sine wave inverter to power corded tools while on the job site. This system also did a nice job of acting as a 'power post' for my Airstream 19CCD when it was being towed by the van.
Installing solar is not really a difficult job, but the system parameters should be set by a pro, someone with experience in the field of designing and installing these systems. Welcome to AM Solar - Your RV Solar Specialists since 1987 would be a good place to start.
Your move................
lewster
09-10-2010, 11:21 AM
2005 22' Safari
Hyde Park Place
, Ohio
Another reason to use a company like Am solar: it's not enough to just be good at math and installations.
Pros like that know the questions to ask to properly figure out not just how you use your system, but just how solar will change how you use your system by changing your thinking about power generation and consumption. Too often, people install oversized systems based on current use, then replace their tungsten bulbs with LED systems, and replace a CRT with an LCD and their power demand halves or more...
Solar affects other systems, so a good review of the other systems is also in order. Replacing/updating other systems might work out as FREE if they cost the same or less than the extra you might have paid for an unnecessarily large system.
TX-16
09-10-2010, 05:36 PM
Cyclist
2007 28' International CCD
Windermere
I waiting for $1 per watt panels.
Seems to me it will be just a matter of time given the green push.
Then I'll plaster the AS roof with enough to recharge the batteries after each day of not conserving.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
09-11-2010, 09:39 AM
1959 24' Tradewind
The Grass Capital of the World
, Oregon
ET Phone Home
Dave Park nailed the usage requirements in his first post, so I'm just going to chime a little as someone who spends a significant amount of time dragging solar panels and batteries into remote areas to power clandestine systems.
The RV installer folks will rip. you. off.
You need a good charge controller between the solar panel and battery bank, which will run you $50 for a $300 85W solar panel (which means 12v at 5 Amps - the math doesn't add up I know, but usually a 12v solar panel will give you 17v of juice at peak hours - thus the need for the charge controller and the definition of an 85W solar panel).
I think 12 gage wire is beefy for RV use, and won't lose too many milliVolts over the length of an Airstream. I think the real concern is how to appropriately mount the solar panel to the roof so that it's durable enough for highway travel. For this reason, I would talk to the folks at AM Solar. They are not the people that will rip you off. Camping World will rip you off.
I can't promote solar panels enough. They are highly tolerant to cloudy conditions and partial sunlight, and even a trickle charge will enable your battery to extend quite a while. Trickle charge is better for your battery life than a periodic large generator charge. The most important thing is to not let your battery drop to below 50% charge, because then it will rarely return to 100%. More like 80%, and then the slow half-life death begins. You want your batteries topped up every day.
Did you know... most laptops and flat panel TVs run on 12 vDC? They convert the AC power within themselves so the high voltage doesn't short circuit their highly sensitive...er... circuitry. So placing an inverter after a 12v battery to provide AC power to a TV that takes AC power and converts it to DC power so the TV can operate is kind of like using a generator: wasteful.
It's 2010. Is anyone else ready to take advantage of the free energy yet?
NO? How about this then...
(2) 85W solar panels, (2) charge controllers, (2) 115-Amp-hour batteries, and wiring materials cost less than $1000. Now you are done and can forget about everything but driving in sunlight and ordinary maintenance.
or
(1) Honda 2000ei for $1000. Now you get to fill up two things every time you go to the pump. Love that price of gas. It's all the way down to $3 a gallon now!
Tom
I'm not sure this is going to happen. Probably about the time solar panels are prevalent is about the time we'll run out of material for PV cells to balance the price. I saw recently that a scientist discovered a way to use a small biosphere to create electricity. Something like 7 different algaes trapped in a glass sphere generate electricity when exposed to sunlight. Cool or weird? That's science for you!
09-11-2010, 09:58 AM
Naples
or
If you're 'satisfied' with 17VDC output from your panels....fine! It's like the proverbial slow boat to china! We prefer the 24.8voc from our panels, which will usually add 50% to the charging amperage seen at the batteries.
And please quantify your term 'ripoff'. What do you do for a living and what do you charge for your labors ( I am NO fan of CW, by the way)? You DID mention that AM Solar will NOT 'rip you off' but where do you get your information and how do you come by your expertise in the field of RV solar? Did you stay in a Holiday in recently?
In all seriousness, the point is to get expert information FROM EXPERTS ! Anything else may be one guy's experience, but is definitely not enough to properly guide you when designing a system for your specific use and requirements. Too many folks on these forums consider themselves 'experts' (or post like they are) after doing a little reading in the internet and/or installing a system for themselves. Sorry, that just doesn't cut it any more, when most of what they say is opinion or regurgitation of some stuff that they may have read elsewhere. Get training, do research, design and install a couple dozen systems and THEN talk to me about 'expert opinions'.
lewster
09-11-2010, 10:32 AM
2008 27' Classic FB
1959 22' Flying Cloud
fairview
, New Mexico
Lewster is right.Doing business requires a bit of a mark up. If companies did not do so they would not be around very long. They are here to provide a service. Not all people can afford to experiment or have the knowledge to do it themselves. I have made my system do what I need. It took some expermentation and $$$ to do this. Lewster and others will do it for you the first time.
Avion C11
1959 Flying Cloud 1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
09-12-2010, 09:14 AM
1959 24' Tradewind
, Oregon
didn't mean to offend
Questions, questions. I'll make this quick - I consider it a ripoff if someone charges me labor that costs 2-3 times the amount of materials to perform the work - a figure I have commonly seen. You probably do not fall into this category. Solar systems and electricity are much simpler than most people think, and they get taken for their dollars because of that. The "ripoff" sentence was perhaps a callous comment.
I require blood sacrifices for my labors. Or bacon.
I acquired my expertise in solar panels from my work, where I build (by hand) a system that measures the strength of the solar wind and uses it to image the geology 500 miles beneath your feet. I also multi-task and try to contact my home planet. Trust me, I've got the photovoltaic portion covered.
What apparently was not communicated well in my last post was that I think solar energy is the way to go and you can save a lot of money if you Do-It-Yourself. As I mentioned before, consulting an expert on certain topics, such as how to properly mount a panel for highway durability, is a good idea.
09-13-2010, 07:01 AM
Edgewood
, New Mexico
That's where I got my system - very good folks to deal with.
2005 GMC CC 4x4 D/A
09-15-2010, 11:23 AM
2008 27' Classic FB
fairview
, New Mexico
Are you asking about voltage?
Avion C11
1973 Safari
1983 34 ft Limited
09-15-2010, 12:38 PM
2005 22' Safari
Hyde Park Place
, Ohio
You can so parallel (+ to +, - to -) to add amperage, or series (+ to - to + to -) to add the voltage.
TX-16
09-15-2010, 12:56 PM
2008 27' Classic FB
fairview
, New Mexico
Rember if you increase the amperage you need thicker wire. If you increase the voltage you will need an MPPT controller which can change the 24 volts to 12 and thus you can use thinner wire.
Avion C11
1973 Safari
1983 34 ft Limited
09-23-2010, 08:25 PM
Santa Cruz
Here is a report on the two solar installations I've done. We boondock mostly, often for a week at a time. I use a CPAP machine which requires a couple of amps all night long.
Solar panels are near $1 a watt now, given the government-subsidized production of raw solar wafers in China. I get mine at Solar Panels - Sunelec : Solar Panels 58˘/W, PV Systems $2.40/W. Making mounting brackets of heavy aluminum angle works fine, and the wires are run down the refrigerator vent.
Batteries are 2 or 4 Trojan T105 6V golf cart batteries. These require maintenance, watering and cleaning but give the most watthour-years per dollar, by a wide margin.
In the trailer, I have one 85 watt panel connected across the battery direct. This is not the best plan because the panel only puts out about 50 watts when loaded down to 12-14 volts. It works if there's decent sun, we usually take a second panel on a cord, that we chase the sun around with if it's shady.
In the motorhome, I have three 130 watt panels connected to a SolarBoost 2000E maximum-power-point-tracking controller which works very well at getting the most out of marginal conditions, allowing the panels to operate at their optimum voltage and precisely regulating the charge to the batteries. The batteries are typically fully charged by noon, even in partial sun. I use 10 gauge wire everywhere.
12-07-2010, 05:14 PM
2007 31' Classic
Kansas City
, Missouri
I have a very clear picture of what I want: two charged batteries each day so I can run my onboard propane heater and have sufficient lights for cool, even cold, nights in national parks. That said, an expert told me that two 100-watt panels and the requisite accessories would probably fill the bill. My evenings in the national parks are spent around a campfire or reading, not watching TV. I'm not arguing against others' use of generators. But in my case, I believe solar is the right answer for the simple requirement of keeping two batteries charged with minimum fuss. I'm prepared for the pummeling of those who hate the idea of solar. But I'd appreciate it if solar proponents would support me. I'm about to put $2,000 worth of panels and accessories, including labor, on my camper. But I have an open mind on the subject. -- John
12-07-2010, 06:07 PM
_
Originally Posted by JBinKC
I have a very clear picture of what I want...But I have an open mind on the subject. -- John
get what u want, why ask or invite 'permission' from others?
i don't see a lot of folks haTing on solar.
it's not free and it's not simple and it's not perfect 4 everyone.
some of us have solar aNd gensets...
exactly what sorta support do ya need?
already consulted an 'expert'?
cool, but i'd suggest repeating that at least one more time.
the expert advise i received here was oVerridden by the company suppling those parts...
what was advised (equipment wise) wasn't gonna work.
experts don't always agree or perhaps rarely agree with each other.
and a LOT of free expert advise is tinted by financial/sales/brand access and so on.
many of the older solar threads provide great details on installs and equipment options.
amps IN reserve is in the range of 100 for 2 grp 27s a third battery adds 50 % more.
spend a week in a forrest or under cover of clouds/rain and the extra battery pays off.
agms require much less maintenance and greater flexibility with installation,
but flooded wet cells work fine and are widely used.
2000 $ isn't much but if U can get all the bits for that, super.
do yer thang, post pix, then go camping.
pummeling is optional.
cheers
2air'
12-07-2010, 06:47 PM
1958 26' Overlander
Mesa
Solar IS the right answer, but you can spend a lot less than $2000 for the setup you want. I just finished installing my system and and only spent $600 for everything. If I can install it, anybody can.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
