Old 01-10-2019, 06:55 PM   #1
2016 27' Flying Cloud
Chicora , Pennsylvania
Solar on 27FB Twin
I have a 27 FB Twin with two A/C units. Anyone put solar panels on a unit similar to mine? If so, what were you able to make fit? Size and brand of solar panels? Thanks in advance for you help and thoughts.
Jerry
Totlh is offline   Reply With Quote
Old 01-13-2019, 06:42 AM   #2
fran&frank's Avatar
Hartsburg , Missouri
I have a 27 FC FB with a queen bed and did my own solar install. Check out my post here or just search Frank's solar upgrade: http://www.airforums.com/forums/f448...-a-164507.html
Frank
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 01-14-2019, 12:54 PM   #3
Frank, Thank you.
This I exactly what I was looking for. Great write up!
I think what I'm going to do is take two 160-watt panels off my other trailer (Lance) before I sell it. This will return the Lance to original. (It had one 160-watt panel on it from the factory).
Unfortunately, I think the 160-watt panels are too big for the top of my A/S. I need to cut some cardboard and see where I can get them to fit. I have been flopping back and forth between mounting two panels on the roof or just using the two as portables.
Did you mount your panels over the top of the shower and bathroom exhaust fans?
Has your setup effected gas mileage?
Thank you.
Jerry
Old 01-21-2019, 03:18 PM   #4
fran&frank's Avatar
I covered the bathroom fan and plumbing vent. I snapped the cover off the plumbing vent so it would have a lower profile, since the solar panel would now act as a cover. To many other variables for me to know if its affected gas mileage.
Frank & Fran
Equalizer Hitch
Old 01-25-2019, 08:24 PM   #5
2018 25' Flying Cloud
Portland , Oregon
I was able to get five 100w Renogy Eclipse panels of my FC25. With a 27 you could probably get one more without cleverness like going over vents.
daleyocum is offline   Reply With Quote
Old 01-27-2019, 06:45 PM   #6
Nice picture Thanks.
WBAC #1341
Old 03-14-2019, 07:45 AM   #7
2019 25' Flying Cloud
Helena , Montana
That picture is super helpful—there are surprisingly few good overhead shots of these layouts. I have a new 25FBT we will be bringing home as soon as the snow melts out on the highways and Renogy 100w panels are near the top of my list. Really want 6... I know 4 is possible easily. Looks like I will have to get creative especially as I have the dual AC model.
mtbackpacker is offline   Reply With Quote
Old 03-15-2019, 07:27 PM   #8
Ardmore , Oklahoma
Totlh
I was wondering if you have made any progress on this solar update? Im also interested in the 160 watt addition you did on the previous trailer as Im looking to buy a 27 FB with the factory install and would like to upgrade it with another 160 watt panel. Is this a difficult thing to do? Was it a DIY improvement?
Soonersalt is offline   Reply With Quote
Old 03-15-2019, 11:06 PM   #9
Portland , Oregon
Originally Posted by Soonersalt View Post
Totlh
I doubt you’ll find any of the experts on this forum that would recommend the factory solar. Cost per watt is way high and the lifespan of felexible solar panels quite short. You’d be far better off having 400w or more of rigid panels installed and a modern Victron controller.
Old 03-16-2019, 08:38 AM   #10
stevejones's Avatar
2019 27' Globetrotter
Martinsburg , West Virginia
We got the factory solar on our 27 FBQ Globetrotter. Initially, I thought it was the way to go. Our battery stayed charged when we were in storage. We always had hookups in our first extended camping adventures so we really didn't use the batteries much. Now we have embarked on a full timing adventure and intend to boon dock as much as possible. Our first parking lot overnight stay with the fantastic fan running all night, using lights, exhaust fan, etc. showed us the current factory solar, battery, inverter set up is not going to be adequate for our needs. We are now planning on a robust solar installation, completely replacing the factory installed solar system, before we really hit the road that will give us the ability to run everything off the batteries.
Here are some thoughts on the factory solar and stock electrical system. Like everything else, it all depends on your intended use of the trailer.
1. The main advantage to the factory solar is all the components and wiring are installed during trailer construction. So if the scope of the system suits your needs it is worth considering. You have a small amount of flexibility to augment the system if you want, but that means spending more money of course.
2. The panels that come with the factory solar are only 80 watts each. That is 160 watts total. That is not a lot. However, the roof installed port has three inputs. Only two are used by the two factory installed panels. You can add a third panel with a Zamp connector and just plug it in and it will be integrated into the system. But if you're installing the same kind of panel you will have 240W. Still not a lot.
3. Your trailer may have a port on the trailer tongue for a portable panel. However if your trailer is like mine, this port is wired directly to the batteries. That means whatever voltage is input there is not controlled by the solar controller in the factory system, so you need to use a portable panel that has an integrated controller. But this also means that if you use a portable panel, the two controllers will be interfering with each other. So if using a portable panel to augment the roof top panels is part of your plan, please know this may not work very well.
4. The AGM batteries that come with the factory solar package are only 80AH each. That's 160AH total. However you should only discharge an AGM to 50% so you really only have 80AH total available. That is not a lot of capacity. You could replace these with higher capacity or lithium batteries if you want, but that could be expensive.
5. On our trailer the inverter is only 1000W. Because of this, only half of the AC outlets are on the inverter circuit and you are limited regarding what you can plug into an inverter outlet. The outlets in the galley, bathroom, and under the dinette are not on the inverter circuit. You could replace the inverter, but proceed with caution since a higher capacity inverter will draw more current from the batteries requiring thicker cables, higher amperage fuse, etc.
Whether the factory solar system will fit your needs depends a lot on how you will use the trailer. If you will mainly camp where you have hookups, then it doesn't matter much. If you intend to use a generator it doesn't matter much. If you are careful about how much you use the battery at night, it may work fine for you. But if you want to boon dock a lot and do dispersed camping, camp at National Parks where there are no hook ups, use the inverter a lot (particularly to power higher wattage things), it may not suit your needs.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4W LT
stevejones is offline   Reply With Quote
Old 03-17-2019, 08:32 PM   #11
Salem , Oregon
I also have a 27fb twin. Can I just wire two panels together on each side and then plug them into the existing plug on the roof. This would still leave one plug available.
NoResults is offline   Reply With Quote
Old 03-18-2019, 12:32 AM   #12
Portland , Oregon
At an absolute minimum you’d also need to install a solar charge controller. That doesn’t come standard in the trailer. Most people appreciate having a battery monitor as well so you know the state of charge.
The wires from the roof probably terminates under the curb side bed, at least they does on my FC25FBT. They will be labeled “solar” and be yellow and green.
Old 03-18-2019, 05:27 PM   #13
Totlh
Both trailers are now at home . I can take pictures of the top of the Lance if you like.
Old 03-18-2019, 09:21 PM   #14
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Solar on 27FB Twin
The Lewster fit 8 panels on our 30’. You should be able to place at least 6 on your 27. Maybe even 7 or 8 depending on where the fridge vent is located - it’s the single biggest speed bump preventing one from laying panels continuously along the sides.
These are AM Solar SP100 panels. 800w total. Puts 56amps @ 14.2v to the batteries mid day in the summer.
We went over the bath and show vents no problem - they still open and vent under 2 of the panels thanks to some extended feet. All gear was from AM solar. More details here:
http://www.airforums.com/forums/f539...-182406-2.html
wulfraat is online now   Reply With Quote
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-19-2011 02:00 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-12-2011 01:50 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-05-2011 09:50 AM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 07-29-2011 09:40 AM
