Originally Posted by Ken J
As far as I know - Lewster is the most competent and knowledgable Airstream solar guy I know - if he installs it, it will be great - he's not a hobbist, he is a degreed engineer whos knows how to do it right - yea you could go the Harbour Freight route, but if you are seriously using your Airstream, it will be more hassle than its worth. Solar is not cheap - but it sure is nice. If you are needing 400 watts, you need a serious system. I've seen a set up that Lewster did and it is AMAZING!
Ken J.
^^^^ X2.
You get what you pay for if you have the very best pro install the very best equipment, all done the right way without compromise.
Lew did my install and I couldn’t be happier to this day. Just a few odds and ends and such... couple batteries, a solar panel or two, a charge controller, easy / quick DIY right? I think not. Worth every penny and I got 30% back in tax credits.
800watts of solar - Eight AM Solar SP100 panels up top. Ability to tilt if needed
Victron 150/85 MPPT controller (Smart w/BT)
Victron 12/3000 Multi-Plus inverter/charger with 50A pass-though
* PowerControl (ability to deal with limited generator or shore power)
* PowerAssist (ability to dynamically supplement the capacity of shore or generator power with batts)
* Real-time uninterrupted 120v power supply when disconnecting shore / genset power sources
Victron Lithium batteries (600ah total - 2 X 300ah batts)
Victron CCGX monitoring panel with wi-fi and automatic upload to VRM portal
Victron BMV-712 battery monitor (Smart w/BT)
Victron Digital Control Center and BMV monitoring panel
Victron BMS
Victron Battery Protects (2)
Victron Lynx 1000 distributor
Victron component networking via VE.Bus and VE.Direct communication buses. WiFi / Internet uplink to Victron VRM portal via CCGX
AM Solar AMS control module for cold weather and other automatic system disconnects
Inverter, battery, solar disconnects for manual manipulation / inclusion / exclusion of components from the system,
New 120v panel and sub panels
New
12v panel
Miles of heavy gauge cabling, fasteners, heat shrink, disconnect switches, etc
WeBoost 50db LTE/4G/3G signal booster with Surecall external antenna and large internal panel antenna mounted mid-ship for re-broadcasting through the trailer.
