Old 03-22-2016, 09:26 PM   #1
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Solar charge controller affect charge from converter?
I have a 2016 FC with factory solar package. I've read about issues with the factory converter overcharging batteries. However the solar package includes the PVCM25D micro-processor based charge controller. Does anyone know if this controller also prevents charging from the converter when it senses the batteries are charged?
fran&frank is offline   Reply With Quote
Old 03-22-2016, 10:39 PM   #2
2015 30' Classic
Pleasanton , California
There is no connection between the Atkinson PVCM25D solar charger and your converter. If your trailer is connected to shore power and you have the Use/Store switch in the Use position, then your converter can overcharge your batteries if this continues for an extended period. To avoid overcharging your batteries with any solar system, it's best to switch your Use/Store switch to the Store position when connected to shore power.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Siemen Solar charge controller dennis3751 Electrical - Systems, Generators, Batteries & Solar 1 09-05-2015 09:45 PM
Solar/ I think I need a new charge controller... Nomad, 2nd Generators & Solar Power 4 05-31-2015 02:34 PM
Whats the best Solar Charge Controller? Keyair Generators & Solar Power 17 05-09-2011 05:04 PM
Where do I connect the solar charge controller on an '87 Soverign? willbrackman Generators & Solar Power 2 08-01-2010 08:11 PM
Univolt replacement now or later, and does solar affect which charge controller? mlepisto Batteries, Univolts, Converters & Inverters 3 11-05-2009 07:16 PM
