Old 10-31-2013, 03:20 PM   #1
jornvango's Avatar
Solar / battery / boondocking
After boondocking for 2.5 weeks, yesterday evening the control panel showed low battery: the water pump barely worked and the fridge lights flickered (eventually I turned off the fridge as it kept making a clicking sound).
These past 2 days, I've been camping in the mountains in Utah: the sun doesn't get up high plus it rises late and sets early.
We have a solar panel on the roof which normally does a good job to keep the batteries charged enough plus I pay attention not to use lights at night and to turn off the water pump when not in use.
I checked the batteries (one month old) and the fluids were pretty low so I added distilled water.
Question: as I usually don't have low battery issues, can this be explained by the low fluid level plus low winter sun that doesn't fully charge the battery? The solar control panel shows between "low" and "good" charging at voltage around 11.
Thanks.
jornvango is offline   Reply With Quote
Old 10-31-2013, 03:36 PM   #2
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Not enough information about your system ... but you're not gonna' get any significant charging if your charging voltage is 11volts. Do you have an ammeter that will give you data about "rate of charge" / "discharge" ? Or something like a Trimetric monitor? Sounds as if you're getting essentially zero charge.
And if your electrolyte levels are low on one month old batteries, that's another sign of some sort of problems; if you have a three stage charge controller, etc. and a properly operating system and are only charging via solar panel(s), you should be able to go months without adding electrolyte.
So you need to get together with someone who knows PV systems and can do some trouble shooting for you. You might want to start by verifying that all your wiring connections are solid, etc. ... 'cause if it worked for 2.5 weeks and then went south, something changed on you.
AirsDream is offline   Reply With Quote
Old 10-31-2013, 03:40 PM   #3
jornvango's Avatar
Thanks. I have no knowledge about electricity and meters.
The main thing that changed two days ago is that I drove from the desert into the mountains.
The past weeks I've been camping in Death Valley: I thought the dryness might influence lower fluid levels in the batteries.
Old 10-31-2013, 05:17 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Fun facts to know and tell
Many solar charging setups have the charge controller powered by the batteries, not by the panel itself. So, if your batteries drop too low, the solar panel worn't charge them anymore once there's not enough juice left in the batteries to run the charge controller.
Can you say, "Catch-22"? I knew that you could.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-31-2013, 06:04 PM   #5
jornvango's Avatar
Good thinking ...
Is there an easy tool (meter?) that allows me to check the batteries?
Regarding LED replacement bulbs: do they only sell these online? I could only find the fluorescent ones at walmart.
Old 11-01-2013, 11:06 AM   #6
jornvango's Avatar
Also, I've been plugged into shore power since yesterday.
1) Battery indicator on the AS control panel shows full. How trustworthy is this?
2) indicator on the solar panel panel: see picture.
Is this (also) showing me that the battery level is almost full?
The solar panel is hooked up to both batteries (one battery on the positive, the other on the negative)
I feel pretty clueless what to look for when it comes to this ... Any help greatly appreciated!
Old 11-01-2013, 11:21 AM   #7
Attachment 199094
Not trustworthy at all while you're hooked up to shore power and your inverter/charger is turned on in either auto/invert or charge modes. The display could be showing the charging voltage rather than the battery voltage. Turn the invertyer/charger completely off and unplug the shore power, then look at the display again.
WBCCI #1105
TAC LA-4
Old 11-01-2013, 12:08 PM   #8
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
You have to wait a couple of hours (not sure of the time), for the voltage to settle down to get a good reading for the battery after charging. Best to get a 'Trimetric monitor' as AirsDream suggested - tell a lot of info you need to evaluate the system - also gives state of charge and volts in and out.
Silver Hawk is offline   Reply With Quote
Old 11-01-2013, 02:25 PM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
Thanks.
The electrolyte (fluid) level in the batteries probably has nothing to do with it. Was it below the tops of the plates?
The low winter sun plus the battery draw for the furnace are the two most likely culprits.
Old 11-01-2013, 02:55 PM   #10
pbearsailor's Avatar
Port Hadlock , Washington
At the risk of muddying the waters more here, the OP says he's been boondocking for a couple of weeks, is careful about using power, has a solar panel of unknown size, and doesn't know much about electricity.
I boondock a lot and am doing so now. For me, it all comes down to knowing voltage. I check my digital readout (his digital readout on his solar charge controller is likely fine for this) when I get up, before the solar begins to put out charge. With no load on the batteries, it needs to read between 12.2 and 12.7. If it reads less than 12.2, I know I have used more than 50% of my batteries and I try very hard not to do that if I want my batteries to last. If it reads 11 volts I have probably killed my batteries. For me, if I'm around 12.2 in the morning, I'll either need a good solar day or that generator is going to have to run for an hour or two.
My guess is that the OP slowly got behind on voltage over that two week period and will be lucky if he hasn't at least shortened his battery life.
Keeping a close watch on voltage is simple and it works.
Cheers,
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 11-01-2013, 08:02 PM   #11
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Took a while but I found that charge controller online & got hints to the age/date of the controller (open the siemens kit and look at photos) .... and it looks like its a couple years newer than your '95 Sovereign. Looking over the little info on the web there is no mention of temperature compensation charging.
So if the Utah mountains in the last week of October is getting into the 20's & 30's overnight the battery chemistry may just be too cold to get even a 25% charge from a days sunshine; compared to the Death Valley daytime highs in the 70's or 80's that kept them charging up to 60 or 80%.
Anyhow - Is the battery compartment on the shady side of the trailer now? That might be a teeny cheat to help them charge, get them warmer. Most 'dumb' chargers want the battery temperature to be between 75 and 80F...
Old 11-01-2013, 09:41 PM   #12
jornvango's Avatar
Thanks. Death Valley got up to the 90s in de daytime! The Utah mountains were in the 30s at night and 50s in the daytime.
I'm still on shore power so, possibly this Sunday when I go back to boondocking, I'll keep my fingers crossed that the batteries provide me with power (I don't have a generator).
Or I can go to Autozone and get a battery checker...
Old 11-02-2013, 07:10 AM   #13
mandolindave's Avatar
My random thoughts
#1 I would call boondocking for two and a half weeks a success story.
#2 I don't have solar, so one or two nights with the furnace running depletes my batts
#3 I have a cheap little meter that plugs into a 12 outlet
#4 Off topic Question ( for Protag ? ) Is it dangerous to work on solar wiring without shielding the panel from the sun.
#5 I haven't spent much time in the northeast mountains of Utah How about a few photos? Please
mandolindave is offline   Reply With Quote
Old 11-02-2013, 07:32 AM   #14
AirsDream's Avatar
1999 23' Safari
If you don't have good portable meters, then do keep an eye on your voltage a couple of hours after "unplugging" from shore power ... and after some minor current draws such as lighting, water heater and fridge circuit boards, etc. That should tell you a lot about the state of your batteries. Your battery voltage should read maybe 12.7 or 12.8 and only SLOWLY drift down while there are small outflows going.
It may just be that you weren't getting enough sun, you single panel is too small to keep up with high current draws such as your furnace fan (probably the biggest single source of battery drain on most Airstreams), etc. That combination could drain your batteries after just a few days, even if the panel were working perfectly. And yes, temperature has a strong influence on battery performance also. But I strongly suspect that the big change was temperature change that led to lots of furnace usage.
In the absence of better metering, keep an eye on your battery bank voltage over the course of some hours to a few days and you'll know a lot more.
