Old 09-08-2018, 04:08 PM   #1
2018 23' Flying Cloud
frisco , Texas
Solar
looking into the Zamp Solar folding kit. i am looking to keep batteries topped off when off grid camping. do i go with the 140Watt or 200watt? 2018 23rb
mjonny is offline   Reply With Quote
Old 09-08-2018, 04:13 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
What you need depends a *lot* on what you will be doing. A 200W (or less) solar setup takes significant effort to run off of for extended periods of time. With care, you *can* run without solar for a week. Many people struggle to run a day or two simply off batteries. The typical system most people seem to go with for "full power" is up in the 400 to 600W range.
Old 09-08-2018, 05:32 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
Zamp 120w 10A Waterproof thru the 7pin.
12days, 3hrs on the Honda 2000i, never got below 12.4v.
Got to float,13.2v most days.
Fridge on LP, WH on LP 1hr/day. FF's on at least 3hrs/day on 1-2 speed. LED lights, no Air Conditioning.
Very good afternoon sun, 2 overcast.
ID:	321893   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 09-09-2018, 10:49 AM   #4
frisco , Texas
so you are using the Zamp 120w and i works fine? I was leaning towards the 160w but would be fine not spending the extra $ and getting the 120w.
Old 09-09-2018, 11:46 AM   #5
Yep the 120 has met expectations, glad we finally got it.
With the Classic batteries hidden behind two compartment doors, charging thru the umbilical cord works very well for us. 👍
I see the 120w has been upgraded to 140w seems to be the same size and weight.
120 is rated at 6.84a, 140 at 6.7 don't know why the lower spec.
W. H. Auden
Amanamus
"Tahawus"
Supplement Factory Solar with Portable Solar dkottum Generators & Solar Power 10 06-16-2016 03:28 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 09:31 PM
Solar Install AM Solar outdoors717 Generators & Solar Power 3 07-15-2012 07:11 PM
