Old 11-09-2018, 08:36 PM   #1
New Borockton , Alabama
Images: 21
Smartplug Promotion
We have noticed many forum members have already (or are contemplating) upgrading their AC inlet and power cord to the new Smartplug system.
We feel this is one of the best products to hit the market in many years. 20X more metal surface contact than the factory plugs = less heat and risk of plug melting or fire.
Bestconverter will run a limited 30 day promotion specifically for Air Forum members.
The promotion will begin Saturday Nov 10th and run until midnight December 9th. Forum members will receive and additional 10% discount and a free weatherproof cover.
Coupon code for the discount is airforums2018
If you are not familiar with the Smartplug or want to learn more, you can visit the manufactures website at smartplug.com
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 11-10-2018, 05:36 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I've installed several of these, and they are easy (not simple) to install. Unscrew the connector from your Airstream, remove the wiring leading into the trailer, and put the new Smartplug on the existing wires. The Smartplug is color-coded to match the wiring, so you can attach the white wire to the white-ringed connection, etc.
Installing the cord end is a little more involved, but not much, and everything is still color coded.
Old 11-10-2018, 06:21 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I cord would be good for us oldfarts...😂
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-10-2018, 10:14 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I like my Smartplug but my only issue is that the little blue light that indicates power is connected has gone out. Any easy fixes?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 11-10-2018, 12:55 PM   #5
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
I installed a Smartplug and really like it so far. No issues.
montanablue is offline   Reply With Quote
Old 11-10-2018, 01:10 PM   #6
2019 30' Classic
Pleasant Garden , North Carolina
Being color blind it is probably not a good idea for me to try this install. I have a fiend who is an electrician so I suppose he could do it for me.
jlandreth is offline   Reply With Quote
Old 11-10-2018, 01:40 PM   #7
Well Preserved
1993 21' Sovereign
For 30 amp, connect the black wire to the terminal with the black ring around it. Connect the white wire to the terminal with the white ring around it. Connect the bare wire to the terminal with the grey ring around it.
Old 11-10-2018, 01:42 PM   #8
eagletoo's Avatar
2018 23' International
Long Island , NY
Does anyone know if the 30 amp Smartplug receptacle is the same depth as the AS stock 30a?
Thanks.
Safe travels, wherever you're bound!
Bruce
2018 23CB International Serenity
2018 Jeep Grand Cherokee 5.7 L Hemi with factory trailer towing package
Equal-i-zer Hitch
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 11-10-2018, 01:48 PM   #9
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Thanks.
Bruce,
It’s not. Going to have to trim a little
Old 11-10-2018, 02:51 PM   #10
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Randy- the link in your signature doesn't work.
2012 Dodge Durango Hemi/AWD
Old 11-10-2018, 09:54 PM   #11
2007 22' International CCD
Smartplug Promotion
Thanks.
It’s very close. I installed one on my rig. The back of the plug shield is against the outside of my shower stall. The original connector also was quite tight.
The smartplug just barely screws down against the outside aluminum shell. A slightly thicker gasket would be nice. Hardest part of my install was removing a half-pound factory-applied blob of sealant off the backside of the hole around the original connector.
Old 11-10-2018, 10:15 PM   #12
2012 Avenue Coach
Corpus Christi , Texas
Same here. My antivirus prevents me & says "Connection not Secure".
rowiebowie is online now   Reply With Quote
Old 11-10-2018, 10:50 PM   #13
Images: 21
Don't know. Has been fine for 15 years. Will have an answer usually withing 24 hours from the host. Orders came in all day so it's something here. Try typing direct www.bestconverter.com
888-828-1893
Bestconverter.com
Old 11-10-2018, 11:00 PM   #14
Images: 21
I just did it and the text link works fine but the one is signature profile does not. Don't have answer yet.
They are working on it.
Bottom line if you want a smart plug you will get one. They are flying out from the end of the rpod promotion and rolling into the Aiirstream promotion. These are the only two we were allowed to promote this year.
888-828-1893
Bestconverter.com
New 50 amp SmartPlug inlet - good location ??? gklott Electrical - Systems, Generators, Batteries & Solar 4 07-16-2017 04:08 PM
SmartPlug hole size gklott Electrical - Systems, Generators, Batteries & Solar 6 05-10-2017 02:39 PM
SmartPlug Rawn77 Electrical - Systems, Generators, Batteries & Solar 14 02-28-2015 08:38 AM
shameless and sometimes rude self promotion Frank's Trailer Works Forum Admin, News and Member Account Info 59 03-26-2008 09:17 AM
