Old 05-09-2017, 05:12 PM   #1
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
SmartPlug hole size
Am replacing the AC shore power cable. Decided to add a power inlet with a separate power cord. Am using a SmartPlug.
Is the primary hole size to mount the plug 2-1/8" or 2-1/4"?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 05-09-2017, 06:19 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The Smart Plug comes with a template if necessary. It requires the same hole size as the original plug.
MICHAEL
Old 05-09-2017, 06:43 PM   #3
gklott's Avatar
2004 30' Classic
Images: 86
Unfortunately, there is no template in the package that included the inlet and the plug for your cord. I searched and found this diagram:
http://www.defender.com/pdf/SmartPlug_BF30.pdf
So, it is 2-1/2" minimum.
2004 30ft. Classic
Old 05-09-2017, 07:12 PM   #4
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
It should directly replace the existing shore power inlet unless there is something unusual about yours. Remove the four screws and you should find it matches. In my case mine pushed up against the inner skin so I had to go inside and cut a hole in the interior skin to make room for the depth of the plug so it would sit flush on the outside.
pcskier is offline   Reply With Quote
Old 05-09-2017, 07:16 PM   #5
gklott's Avatar
2004 30' Classic
Images: 86
I have the built in power cord, and it is showing signs of age and wear. Connector has started to crack, and the compartment is rusting.
So I am adding the plug from scratch as I do an upgrade of the entire AC power system.
73/gus
2004 30ft. Classic
Old 05-10-2017, 11:47 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If there is a website or support line that may be easiest
Otherwise take heavy paper stock like a Manila folder. Cut a strip long enough to go around the circumference. Wind the paper around and tape the ends. Slide the paper off. Keep the circle open so it doesn't change shape. Place where you want to cut and mark the outside of the paper to give you just a little room to have relief...
To mark, you can apply some marker like a China pencil or lipstick of your favorite shade and press to the place you want the circle then remove to see the line it forms...
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-10-2017, 01:39 PM   #7
2015 30' Classic
Springboro , Ohio
I think we used a 2-3/8" hole saw. It was what we had available. It worked fine. I think the original connector had a 2-1/2" hole.
DLMueller is offline   Reply With Quote
SmartPlug Rawn77 Electrical - Systems, Generators, Batteries & Solar 14 02-28-2015 07:38 AM
Awning size; wheel lug nut size jaygoree 2011 - 2015 International 0 02-19-2015 04:18 PM
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 01:04 PM
Plug size and ball size for '66 Safari 22'? Jezibels Hitches, Couplers & Balls 3 08-13-2009 06:59 AM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
