08-28-2019, 12:20 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
SmartPlug
08-29-2019, 12:08 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Well someone needs to chime in here...nice job Ronnie!
08-29-2019, 01:03 PM
2015 23' Flying Cloud
Copper Hill
, Virginia
Yes indeed nice job! Add this to my short list, that really isn’t that short...
08-29-2019, 01:17 PM
Portland
, Oregon
Yeah, my list is growing and we've not even purchased our AS yet!
Thanks, (ugh), Ronnie for continuing to contribute to that ever-growing list!
Cheers,
Bryan
08-29-2019, 01:23 PM
2022 25' Flying Cloud
NCR
, Ontario
i installed it last year
it works very well
i just wish the they made a chord that had a 90 degree option pointing down vs out.
that way there would be less strain on the connector set
08-29-2019, 01:47 PM
Sneedville
, Tennessee
We installed one on our Interstate. Love it, no more busted knuckles or cross threaded connectors.
12-29-2019, 04:43 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Best prices I’ve found are on amazon.
12-29-2019, 06:34 PM
2017 28' International
Virginia Beach
, Virginia
I installed a 50amp Smart Plug last year on our 2017 28 International. It was a walk in the park and has worked very well. The reason I went to the Smart Plug was because I was having problems with the OEM plug. I am fully satisfied.
12-29-2019, 07:24 PM
2007 22' International CCD
Corona
SmartPlug
it works very well
It would be nice and a bit neater, but the connector locks in place so well I suspect it’s not an issue...on a boat the cable is usually draped over a rail or deck edge so it’s not an issue.
12-30-2019, 05:09 AM
Hurst
Yep, great product... Installed it in our 23D a couple of years ago, will not have to worry about loosening, poor connection prone twist lock connector.
12-30-2019, 05:54 AM
2012 25' FB International
Trent Woods
, North Carolina
Time for me to differ. I had the same standard twist lock on my boat that bounced around in its slip, connected to shorepower, most of the year for over 16 years and never had any connection problems. You would think a stationary trailer for many fewer days each year should not present a problem if the plug is inserted properly each time and I have not had a problem.
So I read the hype on these when they came out. Then, because my trailer has two connections, I looked at having to do two of these because it made no sense to carry around two different cords. But the kicker for me was the fact that you can get a standard shorepower cord at RV places, like Walmart, anywhere in the country..not so if something happens to your Smartplug cord. Probably a low frequency event, but I don't need to fix a problem that I don't have. Plenty of other Airstream projects to pursue.
Larry
12-30-2019, 06:12 AM
Hurst
Originally Posted by lsbrodsky
Time for me to differ. I had the same standard twist lock on my boat that bounced around in its slip, connected to shorepower, most of the year for over 16 years and never had any connection problems. < snip >
I was not so fortunate. Our Airstream is. 2014, and the OEM twist lock plug/receptacle was already so loose it was a serious concern. I don't know about "hype," but the Smart Plug is clearly a superior design.
12-30-2019, 07:20 AM
Trent Woods
, North Carolina
I agree, it is a superior design and I have replaced a number of things with something with a superior design. But since I have been using the standard 30 amp shorepower connectors for over 40 years without any problems, replacing those on my trailer is not on my project list. Instead, this month, I will work on replacing my seat cushion foam.
Larry
12-30-2019, 07:35 AM
Overkill Specialist
Dadeville
, Alabama
I did a very extensive review on the SmartPlug system for DIYRV
http://www.doityourselfrv.com/30-amp-smartplug/
Also posted here:
http://www.airforums.com/forums/blog...-install-3080/
While doing my research SmartPlug agreed to send me a set of contact tabs from their system along with a set of contacts from a traditional plug. (Night and Day difference).
Here are a few photos of what the contacts look like inside each plug.
Thought this might add a different view point.
06-17-2020, 04:33 PM
2017 25' International
Camden
, Michigan
Are there any corrosion issues with the stainless steel Smart Plug and the Airstream aluminum? I checked the Smart Plug website and I see they have a grey plastic, but Techno RV does not see to carry the grey, only white plastic, black plastic, and stainless steel.
06-17-2020, 05:32 PM
2018 30' Classic
Williamsburg
, VA
I have had mine for about 6 years now in stainless was absolutely no corrosion issues. Great investment.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
06-17-2020, 05:47 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Nope, haven't read all of the previous posts just happened to see the last pics of the "terminal" details.
Looks like this might improve the shore cord to trailer connection but doesn't change anything about the long standing 30A RV male plug to female receptacle in the pedestal. That connection still has a chance to burn up.
06-17-2020, 06:34 PM
Corona
Personally I’d rather have the overheating at the pedestal end than at the side of my Airstream. The male plug is easy to replace on the road, and I carry a spare.
06-18-2020, 04:59 AM
Somewhere
, South Carolina
I carry a spare cord, male plug and last year I picked up a new trailer end too. 13 yr old trailer end shows no sign of distress.
Early on first season I lost a male end due to a high volume camp with a bad receptacle and this feb I noticed a bad receptacle at a state park, used 50A dogbone and advised camp staff. They replaced it.
It's good thing to be aware of the pedestal
06-18-2020, 07:09 AM
2019 25' International
Providence
, Senior Electrical Engineer
Looks like a great upgrade, I just don't have the stone/heart to start enlarging skin holes to install it.
Good info, thx.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Looking for Electrical System Feedback - Solar, Victron, LiPO4 battery, SmartPlug
Kyacker |
Electrical - Systems, Generators, Batteries & Solar |
70 |
06-23-2021 04:23 PM |
Smartplug Promotion
68 Overlander |
55 |
10-04-2020 11:24 AM |
New 50 amp SmartPlug inlet - good location ???
gklott |
4 |
07-16-2017 03:08 PM |
SmartPlug hole size
gklott |
6 |
05-10-2017 01:39 PM |
SmartPlug
Rawn77 |
14 |
02-28-2015 07:38 AM |
