07-09-2014, 10:02 PM
Montreal
, Quebec
SmartPlug
I came across this interesting company that sells a new power inlet and connector for both 30 and 50 amp solutions.
Their website is www.smartplug.com
I was wondering if anyone has had any experience with this product?
Ron
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
07-10-2014, 12:54 PM
Wise Elder
2010 30' Classic
South of the river
They've been around for a few years.
Fact of the matter is that the twist-lock Marinco plugs work well enough that it's not clear they solve a problem that actually exists.
07-10-2014, 02:28 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Never seen one on an RV. I have seen them on a couple of boats, but boats have this unfortunate tendency to keep moving even after you park them, so there's potentially a lot more strain on the plug. With an RV, there's no movement while you're parked, and no strain other than gravity on the plug. I'm with Jammer on this one… there's no problem with the RV-industry-standard twist-lock plug that would be solved by switching to a SmartPlug.
07-10-2014, 02:34 PM
1995 30' Excella
Bowie
, Maryland
Another concern I have is that if you accidentally damage the connector or something (say drive over it, or the other end of the cord is damaged by a bad socket), now you have a different problem: You're less likely to be able to find parts to repair/replace it locally.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
02-21-2015, 08:54 AM
2007 25' Safari FB SE
Bozeman
, Montana
Good points.
If one damages the connector in Bumfert, TX, can one plug a 15 amp plug into the external receptacle, plug into the 15 amp receptacle on the campground post, and limp along with no air until one gets to a place to buy another plug? Nothing against Bumfert, of course.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
02-21-2015, 10:03 AM
2011 25' FB Flying Cloud
Anywhere &
, Everywhere
The Airstream Store sells the 30A receptacle and power cord. Not cheap. There are also quite a few sellers on eBay. Doubt it is worth replacing the Furrion or Marinco that you have now and the power cord does not have the blue led that the Fussion has to indicate correct wiring
02-24-2015, 12:56 PM
1995 30' Excella
Bowie
, Maryland
Originally Posted by hshovic
Good points.
How hot does Bumfert, TX get? In summer, air conditioning is often a necessity for us.
02-25-2015, 02:01 PM
Bozeman
, Montana
My reference to Bumfert was in jest. Just an acronym for nowwhere near a campingworld....
Hank
02-25-2015, 02:11 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I was talking to a couple yesterday who are full timing and their fifty amp plug had melted.
I think the Smart Plug might lessen this occurrence.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
02-25-2015, 02:31 PM
Wise Elder
2010 30' Classic
South of the river
The Smart Plug is not a replacement for the 50 amp plug that connects to the shore power box. It is a replacement for the connection from the shore power cable to the Airstream.
02-26-2015, 06:07 AM
1995 30' Excella
Bowie
, Maryland
Good points.
I know. My point was, if it's hot wherever you are and you need the A/C, a 15 amp connection isn't going to cut it. The standard connections are readily available; even some campground stores have them.
02-26-2015, 06:20 AM
1966 22' Safari
Hilltop Lakes
All of Texas is hot in the summer. Not so much this time of year.
02-26-2015, 12:36 PM
1995 30' Excella
Bowie
, Maryland
The point hshovic made was that you could still use a 15 amp connection. I responded to say that if you needed air conditioning, then a 15 amp connection wasn't enough. Clearly, I was being too subtle.
I've been in San Antonio in June. I've also been to Dallas in February in the thick of a snow/ice storm without an ice scraper for the rental car. So, I've experienced firsthand the hots and colds of Texas weather. But the point isn't about Texas at all. It's about whether you need A/C when that cord fails.
02-26-2015, 05:55 PM
1972 31' Sovereign
Benton
, Arkansas
I am just going to say that my a/c will run on a 15 amp breaker all day long, although I did install a 20 amp outlet at my home to use instead of the 15.
02-28-2015, 07:38 AM
1995 30' Excella
Bowie
, Maryland
Most won't, or they will but the voltage will be low, which can lead to damage. It's not something I'm willing to risk if I absolutely need AC (we travel with pets).
