Old 02-06-2018, 07:28 PM   #1
2017 25' Flying Cloud
Raleigh , NC
Smartgauge install
I want to install a Smartgauge battery monitor at the bottom right hand corner of the lounge TV in our 25 FC RB. To do that, I need to run a pair of 16 gauge wire from the batteries to the gauge.
I figure I should be able to access the back of that wall through the refrigerator vents near that spot. I will get the wire in through the battery cable opening.
Any suggestions on how to run the wire from the battery cable opening to the back of this wall? I was thinking under the lounge? Or any suggestion for another location?Click image for larger version
JoeHTP is offline   Reply With Quote
Old 02-07-2018, 09:30 PM   #2
2016 30' International
redondo beach , California
Any suggestions on how to run the wire from the battery cable opening to the back of this wall? I was thinking under the lounge? Or any suggestion for another location?Attachment 303699
There are two holes in the floor used to drain the hot and cold water lines. You can use one of the holes to run wires from the outside world to the inside of the trailer.
The wires need to be shielded in some way.
But I'm not sure if this will work for you.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 02-08-2018, 05:59 AM   #3
Registered User
2016 25' Flying Cloud
Fairfield , California
When I was looking at mounting mine, I thought there was a gap large enough between the cabinets and the shell to get the wall. What I did not figure out was how to get it up the wall.
There might be a way from the outside, or possibly cut your mounting hole and fish for the wire?
Mattirs is offline   Reply With Quote
Old 02-08-2018, 08:54 AM   #4
Oak Harbor , wa
Wires from. Batteries to wall by TV
We did this same thing. Could not get anything fished from floor area up to wall by TV receptacle due to internal structure.
Ended up with monitor panel mounted just above TV. I removed microwave above refrigerator, drilled into rear compartment of refer at top, then through floor of refer rear area. There is a 3" void under refer that allows access to wire run where inverted is located. There is plenty of space in microwave cabinet for the monitor.
Stormalong is offline   Reply With Quote
Old 02-27-2018, 08:02 PM   #5
Raleigh , NC
I finally got mine mounted. Cable runs under cushions, between skin and bulkhead into refrig compartment and back behind gauge. Used an electrical project box to mount it.
JoeClick image for larger version
Old 03-02-2018, 03:40 PM   #6
2019 27' Globetrotter
Salem , Oregon
Assuming you have a smart phone why not just use a Victron monitor and read the results from your phone and not have to deal with the extra wiring?
Dave
NoResults is offline   Reply With Quote
Old 03-02-2018, 05:59 PM   #7
Raleigh , NC
Smartgauge is different than Victron in that no shunt is required. But yes, Victron is also a good option.
Dave
Balmar SmartGauge TheCabin Batteries, Univolts, Converters & Inverters 8 01-18-2016 09:11 PM
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
