Old 08-23-2014, 12:39 PM   #1
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
Slow starting A/C
I have a 15K ac that is about 3 years old. It is getting slower to start each time I go camping. Yesterday I turned it on for the first time in weeks. It took somewhere between 5 and 10 minutes to start. I finally turned the fan on and about a minute later the compressor came on. Does anyone have a clue to what may be happening?
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 08-23-2014, 01:36 PM   #2
Zil
egg harbor city , South Jersey
Low voltage can cause slow starting motors, so I would first check all the electrical connections for loose or corrosion. Lubrication?
Zil is offline   Reply With Quote
Old 08-23-2014, 03:05 PM   #3
dznf0g's Avatar
Oswego , Illinois
Are you say it is slow (laboring) to start, or the time delay between switching it on and the fan/compressor starting is lengthening over time....to 5 - 10 minutes. A delay is normal, at about 2 minutes.
-Rich-
Old 08-23-2014, 03:36 PM   #4
1981 31' Excella II
New Market , Alabama
I would suspect the thermostat. I would also check the voltage to rule that out. It should be 110V or above. Does it cycle normally after it starts? It could have a weak capacitor that gets better when it is hot. Also putting an amp probe on it to measure the current would also be useful. Too much current means a problem.
Perry
Slow down when towing - here is why Jim Jarzabek Towing, Tow Vehicles & Hitches 82 07-01-2006 07:53 PM
is the forum slow? john hd Off Topic Forum 1 07-27-2004 07:55 PM
Slow forum home page? Andy R Forum Admin, News and Member Account Info 7 05-03-2004 05:10 PM
Fresh water tank - slow drip drboyd Fresh Water Systems 5 07-24-2003 08:01 PM
Forums slow in the morning? ViewRVs Forum Admin, News and Member Account Info 15 04-14-2003 08:12 AM
