Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-19-2007, 03:10 PM   #1
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
Question Slightly shocking question
Winterizing the camper ('00 Limited) the other day and got a electrical tingle (it was plugged into shore power) when I put a uninsulated knee on damp ground and a hand on the body.
Any suggestions on a possible cause, and where to start?
ebair is offline   Reply With Quote
Old 11-19-2007, 03:15 PM   #2
ebair's Avatar
2000 34' Limited
Miamisburg , Ohio
OOps, just read the post below with the same problem. I'll follow the suggestions there. Thanks.
Old 11-19-2007, 04:15 PM   #3
Either the outlet or an extension cord has reversed polarity, making the Airstream shell "hot."
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-21-2007, 07:15 AM   #4
ebair's Avatar
2000 34' Limited
Miamisburg , Ohio
Thumbs up
Andy,
Thanks for the quick response.
As you suggested I checked the cord and outlet, the outlet in the garage was the culprit (apparently added by a less than competent PO).
So my next little project is to check all the outlets and verify the polarity and wire them correctly.
Has this possibly caused any damage to my coach? What should I look for/check?.
Thanks again
Old 11-21-2007, 08:10 AM   #5
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
no damage, I'm confident. The electrical equipment doesn't care, except in a case, like you, where there was another path to ground. You didn't have a radio sitting on the ground with its hand on the shell, did you?
Zep
Zep@Charmedquark.net
Old 11-21-2007, 10:02 AM   #6
Andy,
Thanks again
No harm done, except maybe to your well being. Not the kind of tingle we choose to experience.
You can get a cheap polarity tester at Home Depot. It will save you considerable time checking out your other outlets.
More importantly, carry it with the trailer as a tool.
When you arrive at a campground or resort, always check the polarity of their electrical service. Not likely, but it could be reversed.
I think everyone should carry a polarity tester.
We all know that there are a lot of shocks in our daily lives, but who would have ever thought that you would get one from an Airstream.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-21-2007, 10:55 AM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I carry the polarity checker in the side pocket of the truck door. I check the Campground outlet before I waste my time backing into a bad campsite.
Zip Dee stores slightly left SafariSogood Awnings 7 10-31-2007 08:22 PM
Shocking Question firedog Shocks 33 09-01-2007 05:42 PM
Slightly overwhelmed 1959newbie Member Introductions 4 02-12-2006 08:51 PM
i am slightly clueless.. roadtrip07 LP Gas, Piping, Tanks & Regulators 10 10-05-2005 08:58 PM
SHOCKing question...... Safari Tim Shocks 27 05-17-2005 07:50 AM
