Old 05-11-2012, 06:59 PM   #1
Day Streamer
gmp61's Avatar
1984 31' Sovereign
Camp Hill , Pennsylvania
Single Outlet Not Working
I am a newbie and took my 1983 Sovereign out for the first time this past weekend. Everything worked great except I had no power to the outlet in the cabinet where the microwave was located. All the other outlets and lights worked, any suggestions on tracking the cause. Another question- The pull switch behind the couch controls the 12 volt power...what position should that be in when hooked to shore power or doesn't it matter.
gmp61 is offline   Reply With Quote
Old 05-11-2012, 07:55 PM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
In our 70' model, over one bed on one side an outlet went out. Because of that location I believe it cut out several outlets all at once. It had been where we were plugging a ceramic heater into for some time.
So I turned off the power to the whole Airstream, and unscrewed the outlet cover. It was fried- or was getting close to. So I removed it and remembered the (very important) arrangement of the wires, and shot down to the electric place and bought a matching new one and installed it. Went outside and turned on the power and everything came back on fine.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 05-11-2012, 08:08 PM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Look for a light switch that turns off your AC. Flip it then check the outlet. They were wired so it was one or the other, not both.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
