Old 07-16-2011, 05:59 PM   #1
1969 27' Overlander
Calgary , Alberta
Simple Q: 30 amp RV cord to 15 amp wall unit..
Hi—first-time Airstream owner, long-time Airstream lover here,
I know there is probably a very simple answer here and I'm over-thinking it. But. The 120v 30amp cord on my 69 Overlander is (obviously) too large for a standard 15amp wall outlet and extension cord. I purchased a 30-to-15 amp adapter but for some reason still have no power in the trailer and "polarity warning" light coming on the Central Control panel.
I checked the manual for troubleshooting—all fuses are good etc. but still only have only battery power. I'd appreciate any tips anyone has to get me refrigerating, microwaving and not draining the battery any more using the 8-track!
Thanks.
Shmeter is offline   Reply With Quote
Old 07-16-2011, 06:08 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The outlet you are plugging into might have reversed polarity. You can get a simple tester at Home Depot or similar stores.
Richard
azflycaster is online now   Reply With Quote
Old 07-17-2011, 07:55 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the outlet test OK. The power cord could be wired wrong. If you plan to run air conditioning you will need 30 amp service.
Here is a site with info on RV wiring. Just click on "Electric" in the right hand column.
www.myrv.us
15 amp, 30 amp, adapter, polarity warning, power
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 39 08-08-2018 10:58 AM
Interior Wall Structure Strip chowman2011 General Interior Topics 3 05-17-2011 08:09 AM
Adding an AC Unit Alamo Furnaces, Heaters, Fireplaces & Air Conditioning 0 04-10-2011 07:51 PM
Question on using 50 amp sevice RLS Electrical - Systems, Generators, Batteries & Solar 16 02-04-2011 01:14 PM
NM Unit and 4CU Jemez Mountains Joint Rally LHall WBCCI Rallies & Events 0 01-05-2011 07:27 PM
