Old 05-07-2005, 04:35 PM   #1
Signal-stat 3101
Anyone have an idea where I can buy a new Signal-stat 3101 7-way male connector? This is the connector that snaps into the socket underneath the front window on our '69 Safari.
Thanks.
Keyholeren is offline   Reply With Quote
Old 05-09-2005, 11:07 AM   #2
The original Signal Stat, male and female connectors, have been replaced with the "Pollak" brand.
They are the same, except for the color.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-09-2005, 11:30 AM   #3
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
9 Way
My 1985 Limited owners manual calls out a 9 way plug type. I have the 7 way on mine.
Anyone have this or can talk to what it all connects too?
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
https://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - https://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 05-09-2005, 11:35 AM   #4
Images: 59
http://www.airstream.com/airstream/p...lug1985-88.pdf
and:
http://www.airforums.com/forum...oto=nextoldest
Old 05-09-2005, 11:36 AM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Signal-stat 3101
Greetings Rob!
Rob
The nine-way connector provided provisions for the Tele-Tector flat detction system as well as a control wire for the refrigerator. The wiring diagram can be found at:
1985-1988 Bargman 9-Way Plug Wiring Diagram
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 05-09-2005, 12:00 PM   #6
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I have that connector too and was looking for a replacement.
But I would like to change it to the 7 way blade type receptical that is used on the car side. The connecting cable would have two identical 7 way plugs on either end.
Is there a 7 way blade receptical with the same bolt pattern as the original signal stat?
Thanks.
-Tim
theVAP - Airstream Podcast
Old 05-09-2005, 12:25 PM   #7
My brother-in-law replaced his signal-stat with the Pollak a number of years ago. It looks good and there have been no problems with it.
If anyone would like pictures of the installation let me know.
The nice thing is that you can pick up the Pollak or Hoppy replacements at any auto parts store.
Anon is offline   Reply With Quote
Old 05-09-2005, 12:30 PM   #8
robandzoe's Avatar
Plymouth , New York
Yes, the trailer has the teletector on it...however the tow vehicle piece is long gone. What was the control wire for the refridgerator used for?
Rob
Plymouth, NY 13832
Courtesy parking
Old 05-09-2005, 03:41 PM   #9
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 194
Signal-stat 3101
Greetings Rob!
Rob
According to the literature that I have read, the refrigerator control wire was a signal as to whether the tow vehcile was running. When the tow vehcile's ignition was turned off it would signal the refrigerator to extinguish the gas flame (for safer fueling) -- then after the tow vehicle was restarted, the sensor would keep the flame off for a period of time to allow the rig to safely exit the fueling station.
I have never owned a coach with this setup, but have known several who have -- I don't know that any of them actually had both features enabled. It is my understanding that it is still possible to find the TeleTector control for the tow vehicle.
After years of traveling with RVs equipped with 3-Way refrigerators (since 1979), this setup always impressed me as being an overly complicated solution to a problem that had been conveniently solved by the addition of the 12-Volt-DC capability to RV refrigerators in the late 1970s.
Kevin
Kevin D. Allen
AIR #827
Old 09-14-2006, 10:00 AM   #10
1976 25' Tradewind
BG , Kentucky
3101 7way Signal-stat
Good Morning all
I need the wiring diagram for the 3101 Signal Stat,, I am not an electrician so a good diagram of both ends would be most thankful, I can find what the wires do but no pics. Seems like the previous owner may of pulled by the wires and pulled them loose. Burned them real bad so I cut the cable back and can't find a diagram to put em back,,
you can e-mail me at r_mizell@hotmail.com
Thanks for any help and your time
Rick,,,pokeman
pokeman is offline   Reply With Quote
Old 09-14-2006, 06:24 PM   #11
AirstreamVT's Avatar
1969 25' Tradewind
1964 19' Globetrotter
Chittenden , Vermont
Thanks.
NAPA Auto parts had a nice all-metal (not steel) option. Be sure to replace the receptical ($14) and the plug-in cable ($10) end together. Mixing a new metal socket and an old plastic end doesn't work, as you may read in other posts. They even had 7-wire cable (14 gauge) with 10 guage ground sold by-the-foot ($2/ft).
Dave
AirstreamVT is offline   Reply With Quote
Old 09-14-2006, 06:44 PM   #12
Dave
The correct cable from Airstream has 4 #14 gauge wires, 1 #12 gauge wire, and 2 #10 gauge wires.
The # 10 wires are used for the ground and charge line.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-29-2007, 01:01 PM   #13
Airstream 65's Avatar
1965 26' Overlander
2009 27' FB International
Winnipeg , Manitoba
Andy, do you sell that cable by the foot?
Airstream 65 is offline   Reply With Quote
Old 03-29-2007, 04:25 PM   #14
We always have that special 7 way cable in stock.
It is sold "by the foot."
Typically 7 feet is required per trailer.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-29-2007, 06:15 PM   #15
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Vintage Trailer Supply sells a nice 7' cable with a molded plug on it already.
-Tim
Old 06-28-2009, 02:33 PM   #16
sbreide471's Avatar
1969 27' Overlander
woodinville , Washington
well i looked at that plug and mine have round hols not slots ?
sbreide471 is offline   Reply With Quote
Old 06-28-2009, 04:09 PM   #17
Pollack makes the replacement connectors for the old Signal Stats.
The 7 way cable can be added to it, as the length from year to year varies.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-28-2009, 05:19 PM   #18
sd90mac's Avatar
Colfax , North Carolina
I would call vintage trailer supply or out of doors mart and ask if the have the one you need. Their staff is very friendly and helpful.
Marie
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 07-15-2009, 06:39 AM   #19
1972 27' Overlander
Wake Forest , North Carolina
Signal-Stat 3101
Perhaps a bit out of date, but I just went through this process. I found an exact match, except all metal (non-ferrous) from NAPA. The part is made by Phillips (USA). The NAPA part number is PHI 15-720 and sells for $10.69. The matching plug which goes on the end of the connecting cable is NAPA part number 755-5025 and sells for $9.99.
bhpowell is offline   Reply With Quote
Old 03-29-2020, 05:00 AM   #20
1970 31' Sovereign
Columbia City , Indiana
Signal-Stat 3101 wiring diagram
I have a 1970 Soverign and need a wiring schematic diagram of the trailer receptacle for the Signal-Stat 3101. The current industry standard for the 7 way connection is not the same. Help will be most appreciated.
landhort is offline   Reply With Quote
28' CCD: Right turn signal blows fuse michaero 2002 - 2005 International 5 11-14-2021 05:17 AM
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Signal Stat 9007 driftwood Electrical - Systems, Generators, Batteries & Solar 6 10-06-2003 06:57 PM
airconditioner Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-20-2003 04:12 PM
