Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-30-2002, 04:00 PM   #1
Andy R
Administrator
Andy R's Avatar
Profile:  1961 16' Bambi
Dallas , Texas
Images: 13
Should I replace the fuse box with a breaker panel?
I have a 1961 Bambi. There is currently a fuse box with 2 fuses in it. What benefits would I have if I switched them to circuit breakers?
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 05-30-2002, 05:12 PM   #2
FrankR
Profile:
Reasons for changing from fuses to circuit breakers.
Fuses are a very good method of protecting any electrical line with any voltage. Fuses can be gotten that will trip with just a .001 amp overload. The next best method of electrical overload is a circuit breaker. All circuit breakers are not the same. Some circuit breakers are made to automatically reset after the unit cools in temperature. They reset even if the problem has not been resolved. The auto c/b just keeps resetting until the fire is really burning or the voltage stops. The best protection is a manual resetable circuit breaker. The fault can be repaired and the breaker reset. These are the most expensive, but they rarely become defective.. This type circuit breaker is used in airplanes and other delicate applications. Circuit breakers rarely need replaced as fuse must always be replaced. Some times looking for a special fuse for an A/S at nite is not fun.......
Name:	as new cb strip.jpeg
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 09-13-2002, 11:21 PM   #3
dragonfly
Profile:
To FrankR,
Where can I get a circuit breaker panel like the one you picture
dragonfly is offline   Reply With Quote
'78 Tradewind labeled fuse box pics & questions BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 20 06-15-2005 07:33 PM
Elec. problem again! davidz71 Electrical - Systems, Generators, Batteries & Solar 48 03-13-2005 06:37 PM
Wanted! Distribution Fuse Panel Reality1 Parts Archive 3 03-26-2004 06:43 AM
Adding second battery box nickcrowhurst Electrical - Systems, Generators, Batteries & Solar 5 02-13-2004 06:26 PM
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 10 08-05-2003 02:42 PM
test
