Old 06-27-2005, 05:40 PM   #1
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Shorted Wire Fixed
Found a shorted wire when fixing the Intellipower Wire problem. Here is the fix.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 06-27-2005, 06:16 PM   #2
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Your website is too cool. I wish I had your creativity (and time to work on my '73!) Keep posting.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 06-27-2005, 06:22 PM   #3
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
Thank you. My wife and I had a goal to document as much as we could to help anybody else working on the same problems we are.
It does take a lot of time to take the pictures and format for the web but it is fun. And I am glad that it is helping some folks.
Old 06-27-2005, 07:36 PM   #4
troubleskeep's Avatar
Richmond , Virginia
Sometimes I'll finish this up with a piece of shrink tube that will cover the whole connection from wire to wire. This is especially beneficial where moisture could be an issue. Just a thought!
  • My mind is like an aluminum trap! Anything caught inside gets turned into an Airstream on the lake.
-Barry & Lisa J
'79 Soverign International @ 31'
2006 GMC Sierra 4x4 2500HD 6.6L Duramax
2001 GMC Sierra 4x4 1500
troubleskeep is offline   Reply With Quote
Old 06-28-2005, 07:02 AM   #5
Somewhere , Indiana
Talking Die electric grease!
All,
Sometimes, when moisture can be a problem, a little die-electric grease can go a long way. I simply dab a little in each end of the splice connector. This can provide a little “extra” life to the spliced joint.
Just my two cents!
Regards,
Henry
axleman is offline   Reply With Quote
Old 06-28-2005, 08:28 AM   #6
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
2 very good suggestions - grease & heatshrink. Obviously I missed that part as you can see in my photos. The dielectric grease is the same type that would be used to conjoin dissimilar metals as would be the case of a house with aluminum wiring. I had a house like that and had to hook up a stove. I used the grease to hook up the aluminum house wire into the plug block for the stove.
Old 06-28-2005, 09:00 AM   #7
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
I would like to pass on some information on "Dielectric grease".
Dielectric - A nonconductor of electricity, especially a substance with electrical conductivity of less than a millionth (10-6) of a siemens.
Dielectric grease is a non-conducting grease and is used for various water proofing situations, check out the link for instance.
http://www.etrailer.com/Merchant2/me...&Category_Code= [moderator edit - after 4 years this link no longer works. check out this alternative for description -- http://www.etrailer.com/p-11755.htm ]
Conductive grease used for aluminum wiring is a different material.
such as Burndy Penetrox-A is used for aluminum wires and is a conducting grease.
check out this link forsome info on these products.
http://www.tessco.com/products/displ...&subgroupId=65
I know that term "dielectric grease" has been used as a generic term but don't mix up the use of this item, you may regret your choice.
Peace
Gary
Janets Husband is offline   Reply With Quote
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Problem fixed lbrodsky 2000 - 2004 Safari 1 12-16-2002 08:42 AM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 07:52 AM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 08:25 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
