Old 10-12-2015, 11:55 AM   #1
1971 31' Sovereign
Savannah , Georgia
Shore power tripping
When I plugged into a standard electrical outlet to run interior lights and ac, it kept tripping the circuit breaker. When I got it home it worked perfectly from my standard outlet. Could I have a grounding problem when parked on concrete? (It is parked in my yard.) Or maybe the outlet was not adequate to handle the load?
strickland is offline   Reply With Quote
Old 10-12-2015, 12:06 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Maybe the first outlet was a 15 amp outlet and the second was a 20 amp outlet?
Or maybe the first outlet already had another load on the circuit?
It is very, very, very, very, unlikely that grass or concrete makes a difference.
Brevi tempore!
Old 10-13-2015, 05:49 AM   #3
1971 31' Sovereign
Savannah , Georgia
That was my guess but was stumped.
Old 10-13-2015, 07:02 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
When you are not connected to a 30 amp shore power source, you are always on the edge of tripping a circuit breaker when running the air conditioner.
It could be the 20 amp vs. 15 amp issue, or it could be the refrigerator and/or the converter cycling on.
In any event, I don't think that parking on grass vs. concrete would have any impact.
Brian
SuEllyn & Brian McCabe
Old 10-13-2015, 09:32 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
When you say Standard Outlet I assume you mean a standar household 3 prong outlet. If so that can be either 15 or 20 amps. In either case that is not enough to run the AC in your trailer unless you take these precautions. Turn off the frig, and the converter. Even doing this it will not work if the receptacle is a 15 amp one and may not work if it is 20 amps and has anything else on that circuit outside the trailer.
2004 Excursion 4x4
Old 10-13-2015, 11:07 AM   #6
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
You need at least a 30 amp breaker, and correct gauge wire for the distance between the breaker and the coach. NEVER allow your voltages to drop more than 10%. Where you park should have zero effect on the electrical system.
NavyCorpsman is offline   Reply With Quote
Tripping ground fault on shore power.A few days ago it was pouring rain so I went to Coaster Batteries, Univolts, Converters & Inverters 4 03-11-2014 03:55 AM
Air Conditioner tripping breaker in my house while on shore power Wgbarrbevco General Repair Forum 10 08-16-2012 06:07 PM
GFI Tripping - Attaching Shore Power Procedure? big_john Batteries, Univolts, Converters & Inverters 0 11-24-2009 07:15 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
