Old 02-08-2019, 04:23 PM   #1
2019 22' Sport
Quartzsite , Arizona
Shore Power Problems...
Howdy,
I noticed 2 weeks ago when I plugged in just a second or two after entering the AS the power came on. I thought a lag was weird but figured another weird thing with trailers.
Today at a new spot same thing BUT power never came on. Gave the panel a gentle kick at the converter and it came on.
I figure loose connection so pull it apart and tighten every thing I can see and look for obvious weirdness. Nothing....
Last time I did it I noticed the red light was not on at the power inlet outside... I guess because no current but would power cord have anything to do with it?
Using a high quality Progressive surge protector and it reads normal.
Have a service appt next Tuesday but wold like to resolve faster if a "homeowner fix".
Any thing I'm missing? Fuses all good and seated well....
Rounder44
Rounder44 is offline   Reply With Quote
Old 02-08-2019, 05:03 PM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Is this the Progressive chart you used to determine “normal”?
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 02-08-2019, 05:26 PM   #3
2019 22' Sport
Originally Posted by Adventure.AS View Post
Attachment 333166
I think so. The one printed on the side
Old 02-08-2019, 07:00 PM   #4
2019 22' Sport
Hmm...
Well I broke out the Progressive PT30X manual and it states there is a 136 second delay when powering up.
I'm confident it was powering up instantly or close to previously as I'd jump in the AS right away to make sure the fridge had shifted from propane to shore power...
Maybe that's all it is?
I had upgraded to the Wildkat converter when I first bought the AS back in October and installed myself. ALL connections are absolutely secure and tight.
Any other clues or advice welcome!
R44
Dometic refrigerator won’t run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 22 04-10-2018 02:57 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
shore power light/convertor problems joel Batteries, Univolts, Converters & Inverters 10 04-18-2009 09:08 PM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
