Old 03-19-2010, 07:04 PM   #43
1965 22' Safari
SALUDA , North Carolina
Exclamation correct wire gauge
Originally Posted by thecatsandi View Post
Depends on the age of your house. My house is full of 20A circuits. The addition in the 1990s has 15A outlets.
I added a 30A RV outlet by the street plus a 20A and an temp switched 15A. Total draw for all three is 40A.
I will be installing a 30A RV outlet where I park my trailer in the back yard. Just have to wait for the ground to thaw.
Both of the eletricians I have dealt with in Missoula will only install 12ga wire. Keeps problems to a minimum.
I hope your electricians are using #10 wire for the 30amp RV recep, or larger if the distance from the breaker panel is greater than 50 feet. Could be a problem with voltage drop starting an roof AC if it is too far and too small of a wire.
Saluda Guy is offline   Reply With Quote
Old 03-19-2010, 07:58 PM   #44
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
This is not uncommon, unfortunately. We've seen LOTS of folks coming here to the park with melted or damaged plugs.
A lot of it occurs, like others have pointed out, by running too much power for the appliance(s) with a corroded plug. In many cases, folks with 50 amp rigs will go to a place that offers only, say, 30 amp outlets, add a little corroded converter between their 50 amp plug and the 30 amp outlet, and try to run everything. The result: A burned plug (assuming that they don't pop the breaker). From there, it spreads like a virus: They take their rig elsewhere, and stick their burned-up plug into a fresh outlet, and burn that outlet to smithereens. And so it goes ...
In large part, that's why we always examine people's plugs (enlightened self-interest: all in the name of helping them "park" their rigs, of course). When I find a burned-up plug, I pull out my trusty pocketknife, scrape off all of the corrosion, then plug it into our outlet.
Lynn
WBCCI 21043
Old 03-19-2010, 08:25 PM   #45
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I love this place!!!
The Forums have come thru again.
My recollection of mention on the 30 AMP outlet for home use.....saved me an AC, fridge, microwave, etc., etc. The 30 AMP outlet that I asked my handyman/electrician to install .....was in fact an RV 30 AMP outlet wired up to 220 volts at the main breaker box. I am sooooo glad that I never hooked into it. He came back today and said that he checked with an RV shop (?) which confirmed the wiring error. I felt quite better after he opened the outside electric panel, disconnected one of the power leads to the circuit breaker, confirmed that the problem was now fixed. Then, as he finished up the "fix" he put his big screwdriver thru the box faceplate to tighten up the last screw. The ensuing flash if light, explosion of sparks, smoke, and noise threw us both back to the ground. The box lid now had a torched like hole in it and the screwdriver was arched in two. I guess I will plan on 12 volt lighting for awhile....till the real electrician gets here.
(see my post today about my 12 volt electrical adventure .....life is exciting here on the ranch......like a Three Stooges film)
Old 03-19-2010, 08:37 PM   #46
Over59's Avatar
Putnam , Connecticut
Images: 37
I'ld get me a new electrian. That is a bone head mistake. Actually it's two bone head mistakes.
Over59 is offline   Reply With Quote
Old 03-19-2010, 10:03 PM   #47
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Lynn
Darn it Lynn, you disappointed me.
I Thought for sure you were going to use your knife to cut the plug off the cord.
Ken
Old 03-19-2010, 10:09 PM   #48
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Ken
Hi, and after you cut the end off of the cord, the camp store sells a new cord for twice the going price.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-19-2010, 10:17 PM   #49
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Nope, I don't cut them off. But I did come across a rig with a plug so bad that I told them that they couldn't plug in. They left.
There's economic sense to the enlightened self-interest: Those outlets cost $18 apiece plus shipping (if I do the installation). If we charge twenty-something bucks for a site (Maria's call) and spend about a third of that on expenses (mostly taxes), that doesn't leave a whole lot left over if we have to buy a new outlet, too.
Lynn
WBCCI 21043
Old 03-20-2010, 09:10 AM   #50
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by Wabbiteer View Post
Dyslexia kitties doing the word processing & posting for Michelle again?
The Ivory colored one is the 120VAC 20A
120VAC 20A has two verticle slots and one horizontal attached to ground side.
Michelle TAC MT-0
Sarah, Snowball
Old 03-20-2010, 10:09 AM   #51
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Whatever it is . . .
. . . the ivory electrical socket on the left that Crawford Gene posted looks like it got into a bar fight. Maybe it was a 120 volt receptacle that walked into a 240 volt bar . . .
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 03-20-2010, 10:10 AM   #52
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
47WeeWind... I owe you one. That was the best laugh I've had in weeks
Old 03-20-2010, 11:20 AM   #53
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Was it a buss bar?
Well, I got the voltage right on those pictures. All the discussion of just what they were proves this to be very confusing. Somewhere on the receptacle it will tell you the voltage and amps. You may have to remove it from the box to find it (after turning off the breaker first) after an "electrician" has installed it. Because I'm sure I'm making a mistake, I read it a few times, sometimes using a magnifying glass if the specs are printed really small. To find a 30 amp, 120 v. receptacle I had to go to several stores, finally locating one at an Ace Hardware.
Gene
Old 03-20-2010, 02:30 PM   #54
tallytwo1994's Avatar
tallahassee , Florida
I'm so glad no one was hurt. Did he forget to secure that disconected hot wire?
In my opinion, it alway pays to call the real electrician first. The whole idea of hidden problems is scary. I feel the same way about plumbing.
Carol
tallytwo1994 is offline   Reply With Quote
Old 03-20-2010, 04:11 PM   #55
1976 25' Caravanner
Campton , New Hampshire
A 30a , 120v , rv plug has a very specific prong pattern . Easy enough to plug into the trailer chord before you hook it up to see if it fits .Wire size will depend on the distance and the amps. When speeking to an electrician you need to specify that it is an 30a RV outlet.
ticki2 is offline   Reply With Quote
Old 03-20-2010, 11:39 PM   #56
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
heres the problem
It was, in fact, an RV plug outlet. As you say RV specific. It was wired wrong to the CB at the plug and the main CB panel. Thats what bothers me, and should get everyones attention....the plug was an RV type and I could have easily hooked up to it.
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Accessing Shore Power Plug on '06 Safari Denis4x4 Batteries, Univolts, Converters & Inverters 5 03-09-2009 12:33 PM
Shore Power Again The Flintstones Batteries, Univolts, Converters & Inverters 13 10-09-2007 07:18 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
Shore power cord FreshAir Electrical - Systems, Generators, Batteries & Solar 18 02-21-2007 02:41 PM
