Old 03-14-2010, 08:14 PM   #29
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by Melody Ranch View Post
I just had a handyman electrician install a 30 amp and a couple 15 amp outlets in a box outside my barn....making available power to any visiting Airstreamer.....and me when parked out under the trees. BUT, before I go any further with it...even test it...I have a nagging recollection that somewhere here in the Forum...a mention was made about being sure that the electrician knew that this was to be power for an RV...not a residence. 220 volts/240 volts something like that. I know nothing about it and and need to be sure about this....any input out there?
The 15 amp outlets shouldn't pose a problem. Let's talk about the 30 amp outlet.
1) Find the circuit breaker that controls it. Does it have one handle, like the 15 amp breakers, or two handles like the breaker for your range, dryer, water heater, etc. One handle =120v, two handles =240 volt, in most cases.
2) You can get a plug adapter here and a meter here for a total of about $20. Plug those together, plug into your outlet, and either peace of mind or the data for a strong letter to your electrician will be forthcoming quickly
3) Or you can just get the aforementioned plug adapter and plug in a regular table lamp with a good old incandescent bulb. If it shines brightly for half a second then burns out your electrician screwed up, if it shines normally everything is fine. The difference is dramatic and impossible to miss, and you won't hurt anything but the 60 watt bulb if the voltage is wrong.
Old 03-16-2010, 05:06 PM   #30
tallytwo1994's Avatar
tallahassee , Florida
If the installer was an electrician and not a handman doing electrical work then I believe he will know if what he installed is appropriate for an RV.
You would use 220/240 volt wire for a 30 amp circuit for say a dryer or stove in your home and those outlets and plugs are designed differently than the 30 amp plug for an RV. Could this have something to do with what you are remembering?
Carol
tallytwo1994 is offline   Reply With Quote
Old 03-16-2010, 05:33 PM   #31
Carol
opps,
I should also mention that you would run 120 volt wire to the 30 amp RV outlet.
Old 03-16-2010, 08:14 PM   #32
Images: 59
Carol
That's not correct. We have more cases of electricians wiring RV outlets with 240V than handymen. I think it's because they just assume anything 30 amps will be a dryer outlet.
Not sure what you mean by 220/240 volt wire vs 120 volt wire. I've never seen wire marked that way.
Old 03-16-2010, 08:42 PM   #33
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I'm not an electrician, but generally there are three wires from the power pole to your house or property; One neutral and two hot 120 volt wires. Usually one of the 120 volt lines operates half of you house's needs and the other 120 volt line operates the other half. If you need 240 volts for machinery or electric appliances they would use all three of these wires. [240 volts] That's how it is in my neighborhood. I would really be leary about an electrician who would think you are going to use an electric dryer out side of your barn. Especially if you told him it is an RV outlet. Not to mention an electric dryer uses a different plug/socket.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-16-2010, 09:38 PM   #34
Images: 59
Generally you are correct. But if you tell an electrician you want a 30 amp outlet on the corner of your house, you're going to get a dryer outlet.
If you tell him you want a 30 amp 120 volt TT-30R RV outlet on the corner of your house, you'll get a TT-30R Recreational Vehicle outlet.
There is a lot of room for garbled, misunderstood and crossed signals. And then you have the electrician that thinks you must have meant a 240V outlet. Then there are the electricians that just have never heard of an RV outlet, so use whatever they have in the truck.
And I happen to have a L14-30R "dryer outlet" on the outside of my garage that powers a small welder, so why would an electrician find that an unusual request?
I'm not saying that the chances are 50-50 that they'll get it wrong, but it happens often enough to be worthwhile asking, as poster #24 did.
Old 03-19-2010, 07:37 AM   #35
I am unaware of any full fledged CERTIFIED Electrician who would confuse a 220/240 30 amp circuit with a 110/120 volt 30 amp circuit for an RV. We work in the construction business and I have been around many, many electricians through the years. True there are some individuals "in training" who might know less, but when somone uses the term Electrician I'm thinking certified.
Sorry for the confusion with the wire. I wasn't saying the the wire would be labled 220/240 or 110/120, rather the wire you use will be different and look different too. When you run wire for a stove or dryer... you use 10 gauge stranded wire conprised of 2 Hots, 1 Ground, and 1 Neutral. Although if you insist you could use the same wire to run two circuits at 110/120 volts, instead of one 220/240 circuit. BUT WHY? Using basic 12/2 Romex is going to be cheaper and easier to use.
Carol
Old 03-19-2010, 11:08 AM   #36
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Receptacles for different amps and voltages are all different. There are 15 amp, 240 v. receptacles. I used one for an air conditioner. They can be hard to find, just like the 30 amp, 120 v. receptacle. Even a licensed electrician can make mistakes.
Here are some pictures of 240 v. receptacles. I think the one on the left is a 15 amp, the one on the right may be a 30 amp receptacle, but I'm not sure. The 50 amp, 240 v. stove receptacle is larger is usually comes in a brown unit.
Gene
Old 03-19-2010, 11:51 AM   #37
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Gene
The one of the left is 20A 220VAC and the one on the right looks like it says L3-20 making it a 20A 110VAC.
Michelle TAC MT-0
Sarah, Snowball
Old 03-19-2010, 01:39 PM   #38
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Dyslexia kitties doing the word processing & posting for Michelle again?
The Ivory colored one is the 120VAC 20A
Old 03-19-2010, 02:10 PM   #39
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I am holding one like the ivory one in my hand right now. It has stamped in the plastic - 20A 250V.
Ken
I use those for my 220v ham radio amplifiers
Old 03-19-2010, 02:41 PM   #40
Ag&Au's Avatar
Ken
After further research the black one is also 20A 250V, but is locking.
Old 03-19-2010, 02:50 PM   #41
Wabbiteer's Avatar
1972 29' Ambassador
Ah yes. My bad. Speaking of dyslexia...
I don't know how many times I looked at that and the horizontal only socket was vertical. Wind in the wires I guess...
Old 03-19-2010, 04:35 PM   #42
Over59's Avatar
Putnam , Connecticut
Images: 37
My favorite story is the guy who couldn't plug his trailer into the outlet on his driveway. So you went to the HD store and bought the "right" outlet for the job. Of course the breaker tripped so he went back and 50 amp break so he could "run his AC". Half burned the house down and the insurance company would not pay. The original outlet was had 14# wire. You cann't screw with this stuff if you don't know how is all comes together. Like Andy says.... people could die...
Over59 is offline   Reply With Quote
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Accessing Shore Power Plug on '06 Safari Denis4x4 Batteries, Univolts, Converters & Inverters 5 03-09-2009 12:33 PM
Shore Power Again The Flintstones Batteries, Univolts, Converters & Inverters 13 10-09-2007 07:18 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
Shore power cord FreshAir Electrical - Systems, Generators, Batteries & Solar 18 02-21-2007 02:41 PM
