Old 06-29-2016, 06:05 PM   #1
2005 22' Interstate
N. Hollywood , California
Shore power not working ??
I just replaced the converter/charger in my 06 Airstream Interstate , replaced house battery too. Switched everything on an all was well
Came back a few hours later after running errands getting supplies for the weekend, there was no AC working inside the van.
I disconnected the new charger it made no difference.
I reconnected charger and ran generator everything worked.
When plugged in I have power to the main breaker but when I turn on any of there other breakers the voltage drops from 120V to 20V or less depending what breaker I turn on.
I am thinking this may be a transfer switch problem. At first I thought it was related to the new charger but not anymore.
I have noticed in the past sometimes the power would not come on and after plunging and unplugging several times it worked.
Looks like its going to be a real pain to get to !
mrcolin2u is offline   Reply With Quote
Old 06-29-2016, 06:15 PM   #2
1978 Argosy 24
Gillette , Wyoming
Does this problem occur when plugging in at more than one shore power supply or always the same shore power source?
sjrcvo is offline   Reply With Quote
Old 06-29-2016, 06:20 PM   #3
2005 22' Interstate
I tried three different outlets. I get 120V to the main breaker with all other breakers off, as soon as I turn on any other breaker the voltage drops to 20V or less and when I turn the circuit breaker off the main returns to 120V
Very strange but I do think it may be the transfer switch because everything works fine when running on generator .
Old 06-29-2016, 08:46 PM   #4
2005 22' Interstate
Sent you a pm SJRCVO. You suggested I check for a loose neutral and thats what is was on the power cord adapter Thanks for helping me out !!
Cheers Colin
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Dometic working on shore power, but difficult to get it running on gas Scott J-24 Refrigerators 28 12-22-2011 03:49 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
