07-30-2015, 08:07 PM
2010 23' FB Flying Cloud
NA
, Here and There
Shore Power inlet failure
We've been hooked into shore power in a trailer park for 7 months now... and all of the sudden our power went out.
The plug is fried and the wires are melted... we aren't sure what happened or really how badly we're screwed. Any ideas?
07-30-2015, 08:09 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Doesn't look fried, just like the wire is loose. Can you insert the wire back in its position and tighten the clamp?
07-30-2015, 08:19 PM
NA
, Here and There
while you may be correct, the screw threads melted on the burnt peg...
07-31-2015, 08:13 PM
1972 27' Overlander
Denver
, North Carolina
Power in campgrounds can vary and you might have had a surge, or the wire might have come loose from travel....or it may have been loose to begin with and through heat fluctuation, worked its way off. Like someone else said, it does not look fried. I installed a Furrion 30 amp locking marine connection. But for now, I would reinstall the wire on the screw and see if all works. If you are not comfortable with this process, hire an electrician to do the repair.
Lucky Dave, Denver NC
07-31-2015, 08:33 PM
Biloxi
, Mississippi
MICHAEL
07-31-2015, 10:14 PM
1999 34' Excella
Hillsboro
We're wires "loose"? That will cause issue of overheating!!! Get that fixed ASAP!!
Peace and Blessings..
Channing
WBCCI# 30676
08-01-2015, 11:38 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
There was an Airstream recall over loose power inlet wiring on recent models.
08-01-2015, 01:03 PM
2007 20' Safari
Old Orchard Beach
, Maine
You may have had a lightning strike nearby. Did other RVs in the park have problems at the same time?
Marty Womer
Old Orchard Beach, Maine
Trailer name: Quarantina
2019-2022 President, Northeast Mountaineers Airstream Club
08-01-2015, 01:34 PM
McLeod
I recently had to replace our Marinco inlet and cord with new Furrion. Not sure, but the cause may have been ants. Once they are attracted to a spot, they can cause a lot of damage. Just a thought.
08-01-2015, 07:06 PM
2014 27' FB International
Clearwater
Looks like you had a loose connection. Looseness creates heat, heat creates higher impedance, more heat, more amps. Parts melt. Replace the connector and consider replacing the plug.
08-08-2015, 04:13 PM
NA
, Here and There
I replaced the Shore Power inlet with a Hubbell, it looks pretty sharp!
I made sure wire connection was very secure... and we have power again!
http://www.amazon.com/gp/product/B00...ilpage_o01_s00
Loose wiring must have been the culprit. Thanks all!
08-09-2015, 03:51 PM
1999 34' Excella
Hillsboro
Originally Posted by Strasser
Shiny!!! Sure you will be pleased for a long time.
Make sure you replace that umbilical, too!
Channing
WBCCI# 30676
