Old 08-01-2015, 08:59 PM   #1
rowesean's Avatar
1976 31' Sovereign
Morehead City , North Carolina
Question Shore power cord replacement
I have a 1976 International 31' Sovereign. The shore power cord was frayed at some point and spliced by prior owner, but gets hot under the electrical tape so I would like to replace the whole thing. Is it better to run the new cord to the distribution panel to keep the wiring "as is", or can I cut the cord where it comes out into the bumper and either install a new male plug there (cheapest option) or instal a SmartPlug or Furrion 30-AMP inlet into the bumper area (there is a lot of rust there, so I am worried about stability)?
rowesean is offline   Reply With Quote
Old 08-01-2015, 09:13 PM   #2
1974 Argosy 20
Kooskia , Idaho
It can be very difficult to get the power cord through the floor/walls to the original power panel. When I did mine over on my Argosy, I spliced a new 30' length onto the original back in the rear bumper compartment where the wire was still good. I used crimp and solder connections and highest quality Scotch electrical tape (#33 or 88) and it has held up fine for about 10 years now.
Old 08-01-2015, 09:23 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
On our 1999, AS apparently changed the design. There was a big square 'junction box' where the external cable connected to the internal cabling. The internal cabling then ran up to the distribution (breaker) box. Maybe you could do something like that?
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-01-2015, 10:21 PM   #4
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Anytime you have a splice or connection you build resistance. Resistance builds heat. If at all possible run the new cord all the way to the inside breaker box. You won't regret it.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 08-02-2015, 10:58 AM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If one disconnects from the interior panel connections and can get to the strain relief on the outside of the box that keep the wire in place, then a gentle -very gentle- small tug by some one outside with someone inside holding the now disconnected wires will give you a clue if there are other intermittent attachment points. Try pulling the the wire a little bit into the box as well.
This exercise determines the viability of the existing power cord to be used as a fish tape or puller for the replacement cord. The challenge many be the existing wiring was not the typical three #10 wires used today for 30 amp service. If they are the same diameter wire cables then making a secure connection outside the trailer to the shortened wire going to the power box would allow the new one to pulled gently into place.
Old 08-02-2015, 07:50 PM   #6
1982 27' Excella
Huntsville , Texas
Shore Power
I have a similar issue with my 1982 Excella. The cable had been spliced and trapped up when I purchased the trailer. A proper made splice should be as strong as the original cable and have no more resistance. Since the trailer I had before this one simply had a receptacle on the trailer I tend to favor this approach but like I said I am still running with a spliced cord. If you can use the old cable as a pull cord this would be an option. The idea of pulling the pans to install the cable does not sound like fun at all.
GMarugg is offline   Reply With Quote
Old 08-12-2015, 03:43 PM   #7
rowesean's Avatar
1976 31' Sovereign
Thanks for the input. I ended up putting a new plug on at the proximal portion of the splice, by which I only lost about 2 feet of cable. I have since removed the interior lower skins in the aft of the trailer as part of the subfloor repair, and now will be dropping the belly skin, replacing corroded frame parts and new belly skin (work to be done by a local metal/welding shop as this is out of my league!). So now the junction box has been removed, and I discovered that there was about 3-4 feet of extra shore power cable coiled under the floor. Now that I have the skins removed, what does anyone think about hooking the main power wire for the trailer to a male plug box installed in the exterior wall (such as a smart plug)? At that point the wall is curved, which may be tricky for getting a good seal.
Sean
Old 08-12-2015, 04:01 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Presuming the cord is the original, you might want to consider replacing... now is the time.. and you will be better off in the long run.
Channing
WBCCI# 30676
Old 08-12-2015, 11:11 PM   #9
1979 23' Safari
Wayland , New York
I removed my hard wired sp cable and installed a furion 30a outlet on the street side just fwd of where the curve ends so it would have a flat surface to mount. Just make sure you have a good idea what's in there before you drill if possible. I had just enough room on mine to get it between the ac drain line and a rib. It's a big hole you don't want to screw up, and highly recommend a properly sized hole saw if you do. The other options I thought of was the back panel to the side of the rear access hatch since there is a little flat space there but didn't like the inward slope. Running the wire along the interior wall low from curb side to street side inside 1/2" nm blue conduit.
If money isn't to tight and buying the smart plug and cable is feasable it seems like a really good choice. Though I think the biggest problem is usually the tightness of the wires not being correct where wire goes into back of outlet.
Old 08-13-2015, 07:00 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
When I installed my Hubbell I shot construction foam between outer and inner skins. But not so much it "bulged" the aluminum. Be careful about that. I then used high nickel content stainless bolts and lock nuts and flat washers as retainers on inside. It is solid.
Channing
WBCCI# 30676
Shore power cord replacement atvmcg Electrical - Systems, Generators, Batteries & Solar 7 03-21-2017 05:55 AM
shore power cord and 12 volt. jpalm1048 Electrical - Systems, Generators, Batteries & Solar 2 09-07-2010 10:46 AM
Trying to replace shore power cord tlavergne Electrical - Systems, Generators, Batteries & Solar 6 08-13-2010 08:51 PM
Shore Power Cord Reel wasagachris Batteries, Univolts, Converters & Inverters 2 06-16-2010 11:28 PM
Shore power cord FreshAir Electrical - Systems, Generators, Batteries & Solar 18 02-21-2007 02:41 PM
