Old 02-19-2007, 06:05 PM   #1
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Shore power cord
The shore power cord on our '66 Tradewind ends/begins at the breaker box...snakes down the wall behind the bath closet into the cavity in the rear access panel. To reach the outside world and a power source it drops through a 3"-3 1/2" plastic drain pipe. So to utilize the cord I have to push and pull it DOWN through that pipe and the same to wheel it in. I would like to install a covered female connection somewhere on the outside skin. Can you clever people offer the best way to make this adaption? And are there any 'kits' available for this? The couple of SOBs I've had had a door to a compartment which the cord was coiled in. I think I would like something better than that.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-19-2007, 06:18 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yes,
west marine sells 30 amp twist lock bulkhead style connectors with a stainless steel faceplate/cap.
john
you call them ferrets, i call them weasels.
Old 02-19-2007, 07:18 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
you have a link?
I would love to replace my grey plastic with somthing closer to the skin color.
Michelle TAC MT-0
Sarah, Snowball
Old 02-19-2007, 07:21 PM   #4
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Neil,
Even with an '84 model, I was not satisfied with the power cord exiting via the rear bumper. I changed ours to an external twist-lock receptacle with cover.
The process went something like this:
Went to a local commerical electrical supply house and looked at all their 30amp twist-lock exterior water proof receps. The one I selected was not on the shelf so it was ordered. Also picked up a 30amp plug to fit the recep. that would be installed on the trailer end of the existing cord.
Waited for recep. to arrive.
Once I had all the parts in hand I started at the main panel and disconnected the shore line.
Measured inside and out to find the right spot to bore a 2" hole thru the exterior and interior alum. (boring thru the skin was the only part of this process that made me nervous. I did not like drilling into the skin but with the right tools everything went fine)
Prewired the new 30A recep. with a short pig-tail for the connection to the main panel. Completed the exterior installation with weather proof cover.
Re-connected power supply that now comes from the new receptacle.
Installed the new 30A plug on the old end of the shore line cable and plugged her in.
Now we have a stand alone shore line cord that is rolled up and stored when not in use.
If you would like to see completed photos I can post in the next day or two.
em.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 02-19-2007, 07:37 PM   #5
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Originally Posted by anholman
The shore power cord on our '66 Tradewind ends/begins at the breaker box...snakes down the wall behind the bath closet into the cavity in the rear access panel. To reach the outside world and a power source it drops through a 3"-3 1/2" plastic drain pipe. So to utilize the cord I have to push and pull it DOWN through that pipe and the same to wheel it in. ...The couple of SOBs I've had had a door to a compartment which the cord was coiled in. I think I would like something better than that.
Neil
Neil, there's plenty of room underneath the closet, next to the water heater for any contraption you want to install, you just have to cut a hole in your skin. I personally have no intention of adding any more holes to the 41 year old skin than I have to. I, too, hate the snake maneuver everytime I set up or tear down. My thought on what I will do some day is cut the cord so it is just long enough to hang out the hole and carry a 30 A extension cord coiled up on top of the Univolt or in the exterior compart, which is on the street side for us, assume it is for you. Then you just pop the cap off of your plastic pipe and from the outside just plug your cord in the plug that is hanging down. Simple, no skin cutting, and no snaking.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 02-19-2007, 08:28 PM   #6
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
best and safest available
Neil:
You want to use the MARINCO line for this. Itís the one john hd is referring to.
It is standard in all current Airstreams and the best and safest available.
You can buy a ďconversion kitĒ or parts separately from either West Marine or Camping World. Consult either or both of their catalogs.
The Marinco cord set features a locking ring that matches the outlet.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 02-19-2007, 11:38 PM   #7
FreshAir's Avatar
1966 24' Tradewind
I too would try not to punch any holes in the skin. If I do maybe in the corner or back near the bumper near where it is now. However, I like your idea of capping that pipe with a short cord inside. It would keep the AS's originality. Thanks, I will consider your suggestion.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 02-19-2007, 11:47 PM   #8
FreshAir's Avatar
1966 24' Tradewind
Originally Posted by john hd
yes,
john
John, Smokeless provided pictures of your suggestion. This may be a little 'heavy' looking for my vintage. I did check out West Marine and they have one that caught my eye but it was a 50 amp. It was a chrome screw cap design. I appreciate your suggestion. Thanks,
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 02-19-2007, 11:53 PM   #9
FreshAir's Avatar
1966 24' Tradewind
Originally Posted by empresley
Neil,
em.
Em, your discription of your installation is very clear. Thanks. I am trying to keep the plug apparatus simple in design to not detract from the vintage appearance of my AS. Is the one you installed as such?
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 02-20-2007, 02:56 PM   #10
empresley's Avatar
1977 Argosy 24
Central , Georgia
Photos
The only thing left is a bead of Vulkem across the top to cover the foam seal. The gray plastic matched well with the exterior alum. Hardly noticeable.
Good luck with your project.
em.
ID:	32714   Click image for larger version
Old 02-20-2007, 03:59 PM   #11
r&kweber's Avatar
1959 22' Flying Cloud
Seattle , Washington
I used the one as shown at VTS:
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Expensive, but well made. The part that gets weather is stainless steel and looks good on the trailer (even better after the trailer gets polished.) The one I installed replaced the broken original from 1959. I had the task of enlarging the hole in the skin and installing a new plywood backing block on the inside of the trailer.
r&kweber is offline   Reply With Quote
Old 02-20-2007, 03:59 PM   #12
Jacob D.'s Avatar
1964 26' Overlander
Alameda , California
I bought the stainless-steel version of this from Vintage Trailer Supply who have it for $100 (but they're out of stock), although Star Marine Depot have it for $75. It's polished so it'd look better with a polished aluminium skin, but maybe too obtrusive with the duller silver of an unpolished or newer trailer.
This is it installed, but before cleaning up the sealant or polishing or even brushing off some dust, so excuse the mess:
There's a patch around it because there was already a hole in the skin here from the original water-fill inlet that was larger than I needed for the electrical inlet. But it also served to give the sheet-metal screws the inlet is attached with a bit more material to hold onto, as the cable's pretty heavy, or someone could trip over it. I also installed it next to a rib (in this case for the hatch below) for a bit of extra strength.
The inside part of the inlet will come at least 1-2" through the inner skin, so plan for that.
(Edit: r&kweber posted while I was composing with similar info. A plywood backing block would probably have been a good idea.)
Jacob D. is offline   Reply With Quote
Old 02-20-2007, 04:47 PM   #13
Images: 59
Here's a picture of the new Marinco inlet on my Tradewind.
ID:	32722   Click image for larger version
markdoane is online now   Reply With Quote
Old 02-21-2007, 01:20 AM   #14
FreshAir's Avatar
1966 24' Tradewind
Great ideas
Yes, Thanks for all the great ideas and pictures of your installations. I am glad that I asked for imput on a seemingly simple project. You have made it much MORE simple for me. I probably would not have even considered the weight of the 30 amp cord hanging and tugging on the skin. Thanks again....now it's time for me to act on your suggestions. I have that area cleared as I am replacing some floor in there and better locate the Intellepower. I also want to address the shore water bib too.
Thank you and I will post pictures of my completed project.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Stand up power cord Happycampers Electrical - Systems, Generators, Batteries & Solar 0 04-18-2004 07:03 AM
External Power Cord Replacement jstaad Electrical - Systems, Generators, Batteries & Solar 3 01-23-2003 06:16 AM
power boosters John Our Community 18 11-19-2002 03:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
