I have a 1975 Argosy trailer. I have two cables coming out from the back. One has 10/3 Type ST 600 volt for travel trailer use : 30 amp stamped on it. I can use that cable. The other cable has both ends cut off. It has Polar/solar 10/4 SEC W A 105 C stamped on it. What is this cable for?
2010 30' Classic
South of the river
I would guess it was adapted to whatever purpose by a previous owner. 10/4 cables are widely used for 3 phase industrial equipment, and it was probably a leftover piece from something.
__________________ Your opinion is valued, please not your opinion of someones else's opinion. Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'... 1954 Feathercraft Vagabond
How long is the 10/4 cable? If it is of useable length you can put new ends on it. Just use the Black; White and Green conductors.
The 4 conductor cables were also used for single phase 240 volt devices such as welders. Black=Hot; Red=Hot; White=Neutral; Green=Ground.
