Old 09-01-2019, 07:31 PM   #1
2008 23' International
Decatur , Illinois
Shore power but no power inside or to appliances
Hello,
My wife and I are newbies to the Airstream world.
We recently purchased a 2008 23' International and are camping in Door County, WI this weekend. We are plugged in to a 30 AMP breaker box and realized today our batteries were being drained thanks to the battery charge system monitor turning orange. Upon further inspection I've narrowed down the following...
When plugged into the shore power and the battery is in "store" mode there is no power to the interior lights, A/C, or fridge however, there is power to the outlets, TV and microwave. We've unplugged the shore power, reset the breakers under the fridge, checked all breakers, added distilled water (very small amount needed) to each of the batteries and their is no change.
From this, we think the the interior lights, A/C and fridge are all running off the battery even when plugged into shore power.
We asked the campground owner to bring his battery charger and the batteries are taking a strong charge (charging 25 AMPs as I'm typing).
So does anyone have any ideas for the following:
1) Why when plugged into shore power will the interior lights and main appliances not work?
2) Why when plugged into shore powder the parasitic battery drain > draw rate to power the interior and appliances?
Thank you,
Travis and Lindsay
Travs17 is offline   Reply With Quote
Old 09-01-2019, 08:47 PM   #2
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
You switched the use/store switch to USE, correct? If no bueno, and the breaker for the converter charger is ok, then check the output on the DC side of the converter with a multimeter. Might be a problem with that.
pcskier is offline   Reply With Quote
Dometic refrigerator won’t run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 23 05-03-2022 05:29 PM
Batteries charging from solar but not shore power johndorst Batteries, Univolts, Converters & Inverters 3 11-16-2016 03:18 PM
HELP?! On Shore Power, but lights dim, and power fades TGadaire Batteries, Univolts, Converters & Inverters 4 11-24-2012 05:18 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
Dometic working on shore power, but difficult to get it running on gas Scott J-24 Refrigerators 28 12-22-2011 03:49 PM
