Old 03-14-2011, 08:10 PM   #1
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Shore power box and breakers?
Ready to get the shore power hooked up and don't have a breaker box. I have looked and looked and don't understand.
Can you provide a link to a breaker box that I can get?
Is the 30 amp 110v or 120v?
What is a two pole breaker?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 03-14-2011, 08:19 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I don't quite understand what breaker box you are referring to. Are yor talking about a breaker box in the trailer or in the house?
30 amp RV power is 110 volt.
A double pole breaker is usually something usually use with 22 volt hook ups for major household appliances, like dryers and electric ranges.
Brian
SuEllyn & Brian McCabe
Old 03-14-2011, 08:24 PM   #3
x
XXXX , XXXX
Daniel look at this and call Randy at best converters. He'll fix you up.
PD5500 50 Amp AC Distribution Panel
wasagachris is offline   Reply With Quote
Old 03-14-2011, 08:25 PM   #4
DanielB's Avatar
Sorry, breaker box for the trailer.
The plug has three wires, black, white, and green, I think,
The trailer has three circuits, 2 for outlets and one for the ac.
I have no clue.
I understand that I will need a breaker on each circuit, like 15-15-30 or something like that.
What I can't find, or it is right there and I'm just not seeing it, is to buy the box with breakers where the 30 amp plug comes in.
- Andrew Carnegie
Old 03-14-2011, 08:28 PM   #5
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Usually airstreams have 120 volt. Your trailer might be kinda surprised if it got wired to 220 volt service. The 120 shore power breaker box in my trailer is in the rear, hiding in the towel closet. Opposite end from the 12 volt fuse box in front of the trailer.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 03-14-2011, 08:31 PM   #6
DanielB's Avatar
Thanks Chris. I saw that before but it was 50 amp with 2 double pole things.
I'll call them tomorrow.
- Andrew Carnegie
Old 03-14-2011, 09:04 PM   #7
Images: 59
You're better off to buy a pre-made RV 30 amp box from someone like Randy. If you want to go on the cheap, you can get any circuit breaker "Main Lugs" box with 6 or 8 spaces.
You will need a 30 amp single pole breaker for the incoming power. Put that in the first space and connect the black wire from the power cord to the screw connection.
Install a jumper between the two main busses in the box. Install the other three breakers in the box.
Make sure the neutral bar is isolated from the enclosure. Buy an extra ground bar and mount it in the box, there should be a location for it. Install all the neutral circuit wires to the neutral, and all the ground wires to the ground bar with no connections between the two.
That should do it.
Old 03-14-2011, 11:43 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
My trailer has an ordinary Square D main lugs breaker box. Came that way from the factory last year. Works great.
Old 03-15-2011, 06:33 AM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
DanielB,
Here's a couple of threads you should read through:
http://www.airforums.com/forums/f37/...lls-74194.html
http://www.airforums.com/forums/f37/...tem-70667.html
Especially the second one. Several of us helped Lindy buy and install a new circuit breaker panel.
Is that all you need? Do you have a converter/charger? Do you have a 12 volt fuse panel? If you need those items as well as the 110 VAC circuit panel, I think you'd be better off buying a complete all in one unit from Best Converters (that's where I got mine).
Chris
Please help identify this wire chingon Electrical - Systems, Generators, Batteries & Solar 22 01-31-2011 07:42 AM
