Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-26-2009, 11:53 AM   #1
Profile:  Silverton , Colorado
Shocking news...
So, I got up this morning, and went out to my moho(parked in the street in front of the home without wheels...opened the door, went inside and turned off the small electric heater we keep there for our freezing mights...went to step out, grabbed the screen door, and got the cr--shocked out of me...being the typical "HUH?" type person, I grabbed it twice more with the same result...so, I unplugged the land line...no more shock, but then I grabbed the voltmeter. With no shoreline power, I get a reading on the 9 volt setting showing a 0.15-0.18 discharge...I get this by touching the screen door with either polarity, and literally grounding the other polarity...I get this reading WHERE EVER i test...back skin to front wheelwell...anyone out there who might know what's going on...?thanks in advance...mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
Visit our blog http://www.scrapirony.com/
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 08-26-2009, 11:59 AM   #2
Head Animal Wrangler
BamCamper's Avatar
Profile:  2006 16' International CCD
Los Osos , California
Egads! I am awaiting an informed response but meanwhile I'm glad you are okay and it didn't do more than curl your hair.
Rally on,
Bam
and no, those photos are not me.
BamCamper is offline   Reply With Quote
Old 08-26-2009, 12:05 PM   #3
You've got my volt...
HAIR...? I have HAIR...?...thank you for your concern...m
Michael & Tracy
1989 345 Motorhome
Old 08-26-2009, 12:18 PM   #4
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
You sure it's not just your electrifying personality Mike?
Seriously...glad you are okay!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 08-26-2009, 12:35 PM   #5
Thanks...I knew I had a spark or two left in me...
I disconnected the house AND chassis batteries...stil showing a 0.18 discharge...only source left for this is the 2 Kyocera 130 solar panels....would anyone know if this is a normal discharge?
Michael & Tracy
1989 345 Motorhome
Old 08-26-2009, 01:19 PM   #6
LHall's Avatar
Profile:  1962 28' Ambassador
Phoenix , Arizona
Mike, I am glad you are okay... but I do believe a perm would add to the TTQ persona...
Anyway, are you receiving .018 vdc? or AC? I did a quick check here at the house. I get the same reading off of the car when I touch a meter lead to ground and one of the wheels on the car. Everything has a minimal amount of voltage. If you were using an analog meter you would have never shown a reading.
My suspicion is you have an issue with your 120vac shore power connection. I would start with your cord and trace back by doing simple continuity checks. I can walk you through some of it if you need me to.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 08-26-2009, 01:41 PM   #7
The discharge is 0.18 DC measured on the 9V setting(don't have a 12V)...
Continuity is something I occasionally am associated with, but I may have gotten conductivity confused with continuity this morning...
The shore line is an extension cord I use for power tools, plugged into an ungrounded base with one of those 3 prong to 2 prong adapters...i ran the cord across the sidewalk under one of those rubber covers that's shaped like a doorsill...we do have a lot of skateboard traffic, so it could indeed be the cord...if you can tell me how to test the cord without shorting out my last two brain cells or setting fire to something, I would greatly appreciate it...I kinda figured that whatever the problem was would make a spark or snap the circuit breaker...hmm, maybe I was the circuit breaker...?
Michael & Tracy
1989 345 Motorhome
Old 08-26-2009, 01:47 PM   #8
Perm...? I have the smallest ponytail on the planet...maybe I could do something with the facial hair...?m
Michael & Tracy
1989 345 Motorhome
Old 08-26-2009, 02:00 PM   #9
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
Mike,
I noticed a trickle on our 81 Excella when it was plugged into shore power via an extension cord (all three prongs) to a friends garage. Actual grounding status unknown. I was checking air pressure in the rear dually tires and got between two metal wheels. I experienced the same trickle disconnecting city water. It was lite but noticeable. Now did you say your wheels were off? Somehow I think this may be related to your attempt to conduct electrons through your meat mass...
-Ken
4CU Charter Member
1981 Excella 280 Turbo Diesel Motorhome
silverback is offline   Reply With Quote
Old 08-26-2009, 02:17 PM   #10
LHall's Avatar
Phoenix , Arizona
Mike, my suggestion would be to try another cord that is grounded!! with all three prongs. Plug in your shore power cable and then take a voltage reading from the side of your MH to the Ground. It should read very close to zero. Make sure you have your meter set to read 120vac. Don't touch the side of your rig until you know there is no voltage present. If you still have voltage after changing cords, would suspect your shore power cable. I can walk you through the check on that if need be.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 08-26-2009, 02:19 PM   #11
Ken,
The wheels were on, I was in my socks, the ground was damp...hindsight can be terribly embarrassing...but I'm still not clear(ok, ok, so I'm not clear on a lot of things) on how I got to be a current event...m
Michael & Tracy
1989 345 Motorhome
Old 08-26-2009, 02:25 PM   #12
grounded...
Thanks...I'll go get another cord, plug it all in, and ask my neighbor to "grab that screwdriver on the counter, would you...?"...
BELIEVE me, I won't be touching anything metal till the meter tells me I can, and I'll be...uhm...apprehensive, even then...thanks for your guidance and patience...m
Michael & Tracy
1989 345 Motorhome
Old 08-26-2009, 02:50 PM   #13
345bill's Avatar
Profile:  Las Vegas , Nevada
WAIT!...I'll send my neighbor over.
345bill is offline   Reply With Quote
Old 08-26-2009, 02:57 PM   #14
LHall's Avatar
Phoenix , Arizona
I have a neighbor to send as well... keep me posted!
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
SHOCKING ... or maybe not FreshAir Generators & Solar Power 22 09-27-2008 10:19 PM
A SHOCKING new development tx-lawman General Motorhome Topics 17 10-01-2006 10:35 PM
Need shocking advise! eikel1we Shocks 9 10-01-2006 02:30 PM
A Shocking Experience dwvh2o Electrical - Systems, Generators, Batteries & Solar 5 07-03-2006 07:23 AM
SHOCKing question...... Safari Tim Shocks 27 05-17-2005 07:50 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
