Setting up a Victron 700 help
I'm not schooled at all in the battery monitoring situation I am currently researching, I have read the manual and believe I have the Victron set right but not sure it's just seems to be very confusing if you don't fully understand the system but this is what I have. 2 Lifeline GPL-24T batts, each with a nominal volt of 12 v, amp hr capacity @ 20 hrs of 80, bulk charge of 14.2-14.4 volts @77* float charge 13.2-13.4 volts @77* now with that info does anyone know what I should have my Victron 700 set at regarding all the settings any help would be appreciated, I also may not have all the info you guys need but just ask, Thank You
2017 FC 28 w/ Shocker hitch
2014 RAM 3500 4x4 mega cab drw
