Old 01-01-2015, 10:48 AM   #15
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
"2 is now correct. I used four six volt batteries on our 12v houseboat for 27 years. Used four Trojan 104s. Had a 1500w Readiline motor-generator to power microwave and espresso maker (not at the same time). Plenty of power for three to four days and nights.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 01-01-2015, 11:35 AM   #16
lewster's Avatar
Naples, FL , Hood River, OR
Sorry guys, but you're still not there. The positive output should be at one end if the bank with the negative output at the other.
That means that the negative output should be on #4 negative, not #2.
While your latest diagram will work, the second bank is relying on the parallel connection instead of creating one big battery as stated above.
Placing the output cables at opposite ends of the battery bank assure you of even charging and even draws.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 01-01-2015, 04:38 PM   #17
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Lew Farber
541-490-6357
But if you create one big battery, won't it be 24V? I don't really like that drawing, so I did my own. Bear in mind that the wires that go into the junction are all the same length...
I started reading this thread, and got more and more confused!
SuzyHomemakr is offline   Reply With Quote
Old 01-01-2015, 05:46 PM   #18
lewster's Avatar
Nope. 2 6VDC batteries is series (pos of #1 to neg of #2 ) create a 12VDC battery of the same amperage (2 X 300 amp/hour batteries @6VDC in series will yield a single 12VDC battery @ 300 amp/hours. Do this between batteries 1/2 and 3/4.
You then connect the positive of #4 to the positive of #2, leaving the positive of # 1 as the output or 'tap' terminal. On the negative side, you connect the negative of battery 3 with the negative of #1, leaving the negative of #4 as the 'tap' terminal. you now have a battery bank of essentially 2 very large 12VDC batteries connected in parallel.
It's the diagrams that are making it confusing! I'll see if I can find a better, easier to understand diagram and post it shortly.
Old 01-01-2015, 05:55 PM   #19
lewster's Avatar
I found an excellent explanation os series/parallel and combo battery connections, but could not copy and paste it here.
The link will take you to a Magnum Energy inverter/charger manual. Scroll to pages 60/61 for color drawings and complete explanations of the process and results.
http://magnumenergy.com/wp-content/u...Series_Web.pdf
Old 01-01-2015, 06:02 PM   #20
ottawa (greely) , Ontario
Here you go ! This is the way it should be done remember short as possible cables and aprox same length.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 01-01-2015, 06:16 PM   #21
Here's the picture of the battery from Lewsters suggested web site .
Don
Old 01-01-2015, 08:33 PM   #22
Tom and Phyllis
Lucky Tom's Avatar
2009 23' FB Flying Cloud
Tuscaloosa , Alabama
When I looked at the two websites, I noticed you had not done a good job re-drawing the diagrams.
I have my entire house on solar power and my Flying Cloud. I used the forum on the Northern Arizona Wind and Sun forums for the information I needed. I am pasting the link to the RV section of the forum, I believe some of you will enjoy it.
Caravan, Recreational Vehicle, and Marine Power Systems
Tom, Phyllis, and Snowy, the white Siberian Husky
2009 23ft FB Flying Cloud
2015 Ram 2500 Cummins Turbo Diesel Crew Cab
LD Valley w/ 800 lb trunion bars
Honda eu3000is generator
Lucky Tom is offline   Reply With Quote
Old 01-01-2015, 08:52 PM   #23
Tom and Phyllis
Lucky Tom's Avatar
This is one of the post from the RV forum.
RV system up and running
I feel sort of... underwhelmed. It's all so... anti-climactic.
I have been studying, reading, posting, learning, And now have my system up and running.
3X Kyocera KC130GT panels wired in Parallel
1X Midnight Kid
1X Whizbang Jr
1X temp probe (they need to use more industrial cabling and make it longer)
1X Outback 500A shunt
2X Interstate GC2 batteries
1X Custom made combiner box with:
3X pushbutton 10 A breakers (0ne for each panel)
1X pushbutton 35 A breaker for combined load.
All panel and charge wiring is 10AWG. Longest run is Kid to batteries, about 20 ft (one way). Panels to combiner are 10-15 ft (ow) and combiner to Kid about 15 ft (ow).
It's all installed in my travel trailer.
Nothing exciting to report. It all seems to be working. I initially had to fumble my way though the menus to fix the AH setting from 416 to 216 AH, but it is all now set right. I am leaving the roof vent fans on tonight to run a typical overnight draw on the batteries to see what my SOC is in the morning, and then see how the system does. My panels are flat mounted, on a slightly curved roof, with one of them sort of facing away from the sun a wee bit. Front of the trailer is facing east, that panel is on the north side.
The batteries are 4 years old, and getting weak, so this is a good checkout.
I guess time for a new project... (Alde Hydronic heat install)
Solar panels in series or parallel - but why not both? drboyd Generators & Solar Power 19 10-16-2017 08:39 PM
'93 Excella... Series or parallel? atomeve Electrical - Systems, Generators, Batteries & Solar 11 04-13-2014 07:25 AM
Battery hook up, parallel or series iamscuba2 Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-15-2011 09:33 AM
Parallel not-alike honda eu series generators malimish Generators & Solar Power 26 02-04-2009 10:26 PM
Series or parallel benwd Batteries, Univolts, Converters & Inverters 52 11-03-2007 08:19 PM
