Old 02-04-2017, 12:40 PM   #1
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
SeeLevel II Battery Monitor
Trading in my 2013 FC 20' and picking up a 2017 FC 23 FB. I noticed AS has switched the monitoring system. Is the SeeLevel II battery monitor any better than the MicroPulse System. I put a Trimetric on the 2013 because the MicroPulse battery monitor was so bad.
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 02-04-2017, 02:11 PM   #2
dznf0g's Avatar
Oswego , Illinois
SeeLevel actually works (if installed properly ) and mine has been flawless.
-Rich-
Old 02-04-2017, 08:07 PM   #3
New Borockton , Alabama
Images: 21
It is night and day better. You will love the SeeLevel but it but it doesn't totalize your amp hours like the Trimetric or have the other features.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 02-05-2017, 07:08 AM   #4
dznf0g's Avatar
Oswego , Illinois
Not only that, but with the SeeLevel monitor being on a long run from the batteries, it reads lower than actual battery voltage. .1 volt in my case.
-Rich-
Old 02-05-2017, 08:14 PM   #5
1996 25' Excella
Shakopee , Minnesota
Voltage error
The voltage reading should not read an error from the length of wires. The volt meter is a high impedance device so minimal current is drawn. Therfore undetectable voltage drop. Meter probably has a slight error
TimeForFun is offline   Reply With Quote
Old 02-05-2017, 08:18 PM   #6
dznf0g's Avatar
Oswego , Illinois
The length of wire does introduce resistance, as well as there may be 1 or more connections between the positive buss and the wall above the counter, some 15 feet away. It is not a dedicated circuit, but I don't recall what else is on that run.
-Rich-
Can you calibrate a SeeLevel Monitor? SeaLevel Plumbing - Systems & Fixtures 7 01-26-2016 09:20 PM
Seelevel 700 series monitor from Garnet Robo104 Electrical - Systems, Generators, Batteries & Solar 3 04-28-2015 06:35 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Seelevel Monitoring Systems rickandsandi Waste Systems, Tanks & Totes 3 10-13-2009 07:48 AM
SeeLevel Gauges 68 Overlander Commercial Listings 11 07-11-2007 11:12 AM
